Eastern Members CT, DE, NH, NJ, NY, MA, ME, MD, PA, RI, VT, VA, WV
What u think,
Old Nov 28, 2011 | 07:51 PM
chknhwk01's Avatar
Talking What u think,
LS6 MOTOR, H/C,175 SHOT, HOW BIG OF A INJECTORS DO U THING U NEED??
WITH ''SCORPION'' FUEL RACEING RAILS, AN WHOS MAKE....
Old Nov 28, 2011 | 08:33 PM
My84Z's Avatar
400 lbs warrierzz!!!!!!!!
Old Nov 28, 2011 | 08:44 PM
SSPerformance's Avatar
buk buk Timmy!!!
Old Nov 28, 2011 | 08:52 PM
MATTREDSS's Avatar
^lol^
you'll prob be fine with 42lb injectors and a 255 fuel pump. Might want to look into stock gm gtp injectors, can pick those up cheap. Might want to ask the nitrous section
Matt
Old Nov 29, 2011 | 08:30 AM
Firehawk441's Avatar
Wet or Dry nitrous?
Makes a big difference for injector size.
Old Nov 29, 2011 | 01:35 PM
chknhwk01's Avatar
Talking u got that right
Originally Posted by Firehawk441
Wet or Dry nitrous?
wet my man...
Old Nov 30, 2011 | 04:23 PM
JS's Avatar
JS
Wet is more condusive to proper pump and pressure but u still need the correct injector for calculated HP...The DYNO tells u how much powa, correct a/f and fuel psi so imo u need to baseline the car on motor, then make the decision based on how much nitrous u wanna run...
I would suggest a 255 fuel pump minimum and a set of 50lb injectors...
This should put u where u need to be but again this is an opinion, data is the best answer.
FUEL SYSTEM CAN NEVER BE OVER ENGINEERED..
JMHO...
Old Nov 30, 2011 | 08:07 PM
Frans96SS's Avatar
At least a 255 intake pump and if its a stock ls6 a stock injector should be fine
Old Nov 30, 2011 | 08:36 PM
chknhwk01's Avatar
Talking Its not stock...
Originally Posted by frans96ss
at least a 255 intake pump and if its a stock ls6 a stock injector should be fine
u did,n read the post,bro, ls6, h,c 175shot.. Full raceing exsaut.
2 pumps, 255 ,plate sys;; 90mm throttle.. Ill thinking on 42ibb
an, scorpion raceing fuelrails...how u think that will work..:d
Old Nov 30, 2011 | 08:46 PM
My84Z's Avatar
42's should work but i would do 50's if you havn't bought them yet as it's always good to have wiggle room!
Warriorz!!!!!!!!
Old Nov 30, 2011 | 10:37 PM
Frans96SS's Avatar
Sorry i missed it. Your English is so proper im not sure how I could not have seen that.
42# will be plenty
Old Dec 1, 2011 | 05:31 AM
chknhwk01's Avatar
Wink sayyyyyyyyyyyyyyyyy whattttttttttt...
42# will be plenty
me speakum good mccoonma, english, ,thank u bro..
Old Dec 1, 2011 | 03:59 PM
Formula413's Avatar
I thing, with a "wet" kit, feul pump is the #1 thing playerz buk buk buk
Old Dec 2, 2011 | 05:03 PM
chknhwk01's Avatar
Talking thanks guys.....
imm aweready hook up.. ready to go,
