Eastern Members CT, DE, NH, NJ, NY, MA, ME, MD, PA, RI, VT, VA, WV
UD pulley help
Old Jan 23, 2012 | 09:54 AM
JTblack02SS's Avatar
Default UD pulley help
Hey everyone, I'm currently changing the heads and cam on my 02 SS. I'm putting the UD pulley back on and got it about a 16th of an inch away from being flush with the crank. Now the problem is if I keep running the old crank bolt in to get the pulley all the way on am I runnin the risk of snapping the bolt off in the crank? That's what I'm afraid of. I've been using a breaker bar and torque wrench, but would I be ok to put a longer pipe over the wrench for more leverage?
Old Jan 23, 2012 | 11:45 AM
BAD ASS TA WS6's Avatar
BMW ///M Nerd
Using the old bolt is def. Not a great idea. A forum member here used to sell an install tool he came up with for 20 bucks. Threaded rod with a couple of soft washers and a large sleeve w/nut. It works the ***** and no risk of damaged threads in the crank snout. Check out the tools section. Id give u a link but itll take forever on my phone
Old Jan 23, 2012 | 01:04 PM
Ok cool thanks man
Old Jan 23, 2012 | 01:34 PM
BMW ///M Nerd
Aftera quick search, member 516hawk makes/sells it and byunspeed sells it as well
Old Jan 23, 2012 | 01:47 PM
IDriveChevy's Avatar
Use the old bolt to press the pulley flush, remove old bolt and install new one.
