My G8 ate a lifter and cam
I just got the call from the dealer service dept ( car is still under warr) and the light tapping noise my wife heard turned up to be one of the displacement on demand lifters had failed at its roller and that in turn wiped the cam lobe. Now the car is waiting for the parts to be shipped in. Turns out that the valve train for the 6.0l Gt is not that common. they would not convert it to a LS3 system due to the fact that GM is paying the bill so all stock.
If GM did not step up and pay it would have been on a trailer down to Slowhawk for an aftermarket cam and removal of the DOD system
See this all the time lately. Not just in the g8s. Have had a bunch of newer 6.2l Denali truck and yukons loosing lifters, cams, few have broken valve spring and trashed the engines. Used to never have all these issue with Gm engines and wiring might i add. Really a disappointment.
I think there was a change in oils about two years ago, I never saw a lifter wheel worn the way pattern Ive seen a bunch of them since. Starts out as a tick, then a tap and then chews **** up. If you catch it early, they have all looked like the wheels are skipping across the lobe, not a valve bounce necessarily, just skidding.
Gm say this is normal if it go's away once it warms up. What a joke. They say its is caused by carbon on the pistons and because of the 6.2 not having larger piston skirts, Heres the bulletin # 01-06-01-028B
Oooo yea, it also says this in the bulletin in a high lighted area.....Important: At this time, attempts to repair this condition by replacing the engine assembly or pistons are not recommended.
