Eastern Members CT, DE, NH, NJ, NY, MA, ME, MD, PA, RI, VT, VA, WV
talk me out of it...
Old Feb 1, 2012 | 09:19 PM
SVTconfused's Avatar
Default talk me out of it...
As you kno I recently purchased my z28 knoin it needed a clutch and had a miss...
Well it appears the miss is mechanical... however I am pushing 155-160 psi compression...
So my options are
A... drop the motor out... replace it with a lq9 build of sorts... throw it back together...
B. Part the thing out and just move on... reason why I'm considerin partin it out is because it has a rather messed up quarter... needs a bumper cover and paint... uggg...
However I have a guy willin to take my lightning...(multiple colors... needs body work and paint as trade for all the work on the camaro...
Mannnnnnnnm
Old Feb 2, 2012 | 01:40 AM
Frans96SS's Avatar
Why dont you figure out what is causing the miss first.
Old Feb 2, 2012 | 12:38 PM
Cool28's Avatar
Tire Smoking Tranny Blowing Director
Hell could be a bad injector lol
Old Feb 2, 2012 | 04:15 PM
MynameisLee's Avatar
What kind of mechanical? It sort of hinges on what the actual problem is to make an informed decision.
Old Feb 2, 2012 | 10:55 PM
I've moved injectors around... I've moved coils around... I have spark and a injector pulse...
Old Feb 2, 2012 | 10:57 PM
I've already talked myself out of partin it out... so it all hinges on a leakdown test imho
Old Feb 3, 2012 | 07:18 PM
Specialized's Avatar
Miss can be caused by something in the intake that would not show up with a leak down, fyi..
Old Feb 14, 2012 | 07:44 PM
turns out its valve related... did the ole pour water in the intake port with the head on the bench test... it poured out as fast as i could fill it on #6...
what was/is odd tho i pulled the other head off and noticed #5 piston has at one point slammed the intake valve pretty damn hard... leading me to think this motor has been appart before...
it also has 2.08/1.64 which i dont know if that stock or not for a stock ls1 head...
