any GM techs
Any techs ever heard/seen this problem?
Had my 08 Mailbu at alignment shop, and while it was on the rack, the battery went dead. The guy jumped it and ever since then, the TPMS & the remotes quit working.
I found the bulletin below and it describes my situation exactly.
Is there any quick ways or tricks to fix this myself, or am I going to have to go to a dealer?
08-03-16-001B: Key Fobs Inoperative, TPM System Not Reading Correctly - Dashes on Al Four Tire Readings, DTCs C0775, C0569, B3105 Set, Unable to Program TPM Sensors (Reprogram RCDLR) - (Jul 31, 2008)
Subject: Key Fobs Inoperative, TPM System Not Reading Correctly - Dashes On All Four Tire Readings, DTCs C0775, C0569, B3105 Set, Unable to Program TPM Sensors (Reprogram RCDLR)
Models: 2008 Chevrolet Cobalt, HHR, Malibu
2008 Pontiac G5, G6, Solstice
2008 Saturn AURA, SKY
This bulletin is being revised to update the Important statement to reflect the new direction to no longer contact TCSC. Please discard Corporate Bulletin Number 08-03-16-001A (Section 03 - Suspension).
Condition
Some customers may comment that the key fobs are inoperative or that the TPM system is showing dashes as the reading for all four tires.
Technicians may find DTCs C0775, C0569 and B3105 set simultaneously in the RCDLR module.
In addition, the technicians may find Tire Pressure Monitoring sensors are unable to be programmed to the vehicle by adding or releasing pressure to the tire while the vehicles in the TPM learn mode.
Cause
These conditions may be caused by the following:
• The RCDLR may lose its transmitter and tire pressure monitoring data from its memory if a low voltage condition occurs on the vehicle.
• The ability for TPM learning by adding or releasing pressure to the tire has been disabled in the RCDLR.
Correction
Reprogram the RCDLR with an updated software calibration to address both issues listed above. This new service calibration is available on TIS2WEB using Service Programming System (SPS). As always, make sure your Tech 2® is updated with the latest software.
Important: If the Tech 2® could not establish communication with the RCDLR AND the programming event ended with error, attempt to reprogram in Service Programming System (SPS) by selecting "Remote Control Door Lock Receiver (TSB 08-03-16-001) with E4399 error -- Pass Thru Only".
Once the RCDLR module has been reflashed with the latest software and calibrations, the following may also be necessary:
• Relearn all keyless entry transmitters.
• Reconfigure the tire pressure placards and the tire type.
• Relearn the tire pressure sensors.
Refer to SI for the procedures to relearn transmitters, placard and tire type configuration and tire pressure sensor learn.
He called "someone at GM" and they told him to unhook the battery cables and hold them together to completely drain the voltage.
It didn't work.
Thanks
So...appt at Chev dealer this morning after the alignment shop and myself talked to them earlier this week. In other words, they knew I was coming and what the problem was.
Assured me it was a 30min job. No problem.
Wrong
Picked it up with the excuse that they only had oil change techs working Saturday and they couldn't figure it out. Very frustrating but I need to get it fixed. Made the appt with a "Master tech" this week.
Hey man the bulletin says the Rcdlr needs to be reflashed .........
I've seen it several times ... Just kinda like its brains fell out ....
Take it to the dealer have them reflashed your Rcdlr and learn the moniters. ...
Good luck
I would say 1 hours labor charge
