New Summit Pro LS Cams in our Ohio and Georgia stores
LS1Tech Sponsor
Received 1,121 Likes
Good news, the new Georgia store just received our new Pro LS cams into stock this week. If you in the area, you can pick one up now! We're attaching two lists. One is a list of the cams and the other is a list of the common things needed when doing a cam swap. We've found it easiest just to print it off and stick it on a toolbox with magnets. Our 2017 lineup of Single Plane cams was a good start, but the next series we released on Independence day is really killer. We now have them divided into Automotive, Turbo, Single plane, and Vortec Truck swap cams. Note they are not for sale or use in pollution controlled vehicles.
They are Made in the USA with U.S. bearing steel and manufactured with great lobe designs. They are ground on a Landis with Diamond CBN wheels. They are designed around commonly available spring kits etc. to keep a cam swap affordable.
Most here are familiar with the individual valve events and their affect on performance and behavior. You'll note we've designed the cams with the opening and closing points in exacting increments so you get the performance and idle you're looking for. Here is the basic article on the Summit Pro LS Cams. The valve events are off to the right of the tables, so you may need to scroll over if you are viewing on mobile. There is also an article on Valve Event theory you may enjoy. Lastly, there's an article on the Summit Pro LS manufacturing process behind these cams.
We're adding to this lineup so let us know if you need anything or have any questions.
