Eastern Members CT, DE, NH, NJ, NY, MA, ME, MD, PA, RI, VT, VA, WV
NED 2005 rule change
Old 11-17-2004, 05:55 PM
WJ SOM SS's Avatar
Everyone's worrying about this roll cage rule.....Did you ever see one of these F-cars break a c-clip axle at around the 1000 ft. mark? Or better yet, break a U-joint on a car without a driveshaft loop while going thru the traps? That's when the brown-stained underwear come into play.....
Old 11-17-2004, 05:57 PM
Moderator
davered00ss's Avatar
I need a DS loop.
Old 11-17-2004, 06:28 PM
My84Z's Avatar
**** I am still going for 11's motor. this blows!
Old 11-17-2004, 06:33 PM
ButchN's Avatar
Originally Posted by JL ws-6
sounds like you'll be going to LVD with the rest of us. Welcome aboard.
While the rule changed, seemingly overnight, LVD is quite the haul for me, like 2.75 hrs & that's A LONG WAY away from home in case of breakage where as NED is like 45 mins away & my premium AAA (towing good for 100 miles or less) would get me back home.
Old 11-18-2004, 12:56 PM
tbyrne's Avatar
Rollbar / Rollcage: A minimum of a 6 point roll bar is mandatory all convertibles running 11.00 to 13.49 ¼ mile
I'm probably going to put a Magnuson on my C6 when it comes in so that should put it somewhere in the mid 11s. There is no steel tubing going in that car! At least it will be fun to drive on the street.
Old 11-18-2004, 01:42 PM
Humanitarian
Joe "Preachers Sheets" DIESO's Avatar
Even without the charger your going to need the roll bar.
They dont inspect the cars all that well anyhow, as long as the bar is in there and the mounting brackets are under the rug they'll never know.
Old 11-18-2004, 03:23 PM
WJ SOM SS's Avatar
Joe............
