paging slowhawk, need sum help
PDD, Doesn't sound like its the tranny/tube/rear since the tires lock in gear and spin in neutral. All I can think of is that the clutch is not engaging. I know that dosen't make sense because I assume you are changing gears but I can sometimes change gears 1-4 without the clutch with the car off. Can you get into reverse when you throw in the clutch?
"i didnt remove the clutch but it looks good. the pilot bearing looks good too. i checked for stripped splines on everything. nothing. it all looks new. the only thing left is to pull the clutch and get a closer look at it, "
from they guy doing it so I'm confused?
i hate this ****** car. im going out and tank it up
hope not
