Eastern Members CT, DE, NH, NJ, NY, MA, ME, MD, PA, RI, VT, VA, WV
Head and Cam Packages in NNJ
Old Mar 26, 2005 | 03:21 PM
NJgunslinger's Avatar
Default Head and Cam Packages in NNJ
Who do you guys recommend in North Jersey to work on Ls1's. I'm looking for a good place to get a head and cam package and to have them install it. I see CArtek has some good looking packages, anyone get them and how do you like it?
Thanks, Sam
Old Mar 26, 2005 | 06:01 PM
1RawTA's Avatar
if ur looking for a head and cam package the guys at TTPerformance can take care of you.. .. if you want give matt a call at the shop 973-365-2270 he can give u some pricing info
Old Mar 26, 2005 | 07:43 PM
DarkSideSS's Avatar
I second TTP..they're a great bunch of guys who build some great cars.
Old Mar 26, 2005 | 08:23 PM
Jersey_TA's Avatar
I third TTP
Cartek = $$$$
Old Mar 26, 2005 | 10:12 PM
SSPerformance's Avatar
do it ur self and save ur self some $$$$$
Old Mar 27, 2005 | 07:56 AM
Miriah's Avatar
Sponsor
Give Dave a call at the shop 908-317-4496. The cars that we put together speak for themselfs. Not only do they run the number but they hold up. My Formula was my daily driver right up until I sold it and is now the daily driver of the guy I sold it do
www.cartek.net
Old Mar 27, 2005 | 12:18 PM
LS1LT1's Avatar
Thumbs up
You've seen correctly.
I have quite a few friends/acqaintences with Cartek heads and cam (among other) packages on their cars, they're all fast (with proven track times) and they're all quite reliable for the power levels they are making.
They've done most of the work on my car and their level of expertise is very high.
Good luck in whatever you choose.
Old Mar 27, 2005 | 04:18 PM
9-SEC NA C5's Avatar
Cartek can hook you up . Call Dave , I'm sure he'll work a nice deal out for you .
Old Mar 27, 2005 | 06:10 PM
RahuL's Avatar
Thumbs up
Another vote for TTP.. got all my mods/tune done there, and been very satisfied with the results, professionalism and service!!
Old Mar 27, 2005 | 06:36 PM
scottywheels's Avatar
I would say cartek but if you want to come to CT call me at eastside....203-269-1539
Old Mar 27, 2005 | 08:20 PM
Durien's Avatar
my car is my daily driver.... all work was done by cartek.. look at my sig for mods
Old Mar 27, 2005 | 10:19 PM
Anonymous's Avatar
10 second playa
My vote is for Cartek.
They have everything right there on the premises.
Chassi Dyno, Head Porting, Flow Bench, Injector Balancing, Cam Doctor type analysis equipment, Welding and Fabricating, State of the art CNC operated machines, Pipe Bending, Engine Assembly, tons of (positive) experience and one of the (if not the) best tuners in the country.
Do I even need to mention all of their current records and "Firsts" throughout the years?
They stand behind their work and they have been around for a long time.
( The test of Time and Quality )
If they were not the Best, I simply would not be going there!
Old Mar 27, 2005 | 10:28 PM
WS6TransAm01's Avatar
CARTEK Racing
CARTEK 4 LIFE!
No one else has, is or ever will touch my car. I ran an old CARTEK H/C set up. Tey were 98 heads and a tiny tiny cam. Ran 11.3 @ 122 with it almost 3 years ago. NOw I have a newer set up and LOVE IT!
Call Dave and you will not regret it.
P.S. If you want to same some cash. I have something
PM Sent!
Old Mar 27, 2005 | 10:49 PM
Jammer's Avatar
Cartek does consistantly deliver a quick ET but its a few extra bucks.... worth it to most. I'd say products are top notch with typical NNJ friendliness.
Old Mar 28, 2005 | 01:28 AM
DocEwww's Avatar
Cartek or TTP...cant go wrong with either.
Old Mar 28, 2005 | 10:08 AM
TTPMatt's Avatar
You will find out packages very price competitive. If you have any questions please give us a call or come down and chat. 973-365-2270.
We have numerous people with our Equalizer series of cams running them in their daily drivers so streetability is not an issue.
Here are the packages:
TTP Stage 3 Equalizer Heads/Cam Package
TTP AFR 205cc CNC Heads with Dual Springs, Titanium Retainers - Finish Ported/Polished by TTP
TTP Equalizer V.3 Camshaft
TTP Hardened Chromoly Pushrods
Rollmaster Double Roller Timing Chain
SVO 30lb Injectors
GM Steel Headgasket Kit
(2x) GM Headbolt Kits
(2x) AIR Gaskets
(1x) EGR Gasket (If needed)
GM Timing Cover Seal
GM Timing Cover Gasket
(2x) GM Waterpump Gaskets
Installation
LS1 Edit Full Custom Dyno Tuning (Part throttle, wide open throttle, custom timing map, removal of engine codes)
$4799.95 Turn-Key (Add $100 for Corvettes)
Options:
LSX 90mm Port Matched Intake Manifold with FAST or NW 90mm Throttle Body - $1465 Installed
Meziere Electric Water Pump with Relay - $550 Installed
Kooks 1 3/4" LTs with 3" ORY - $1000 Installed (Add $260 for Cats) (Add $200 for Corvettes with X-Pipe)
TTP Stage 3 Equalizer Package Results:
This package just made 482rwhp/418rwtq through a 2002 Camaro M6 with LSX 90mm, Mez Electric W/Pump, 4.10 gears, SLP Loudmouth, Kooks 1 3/4" LTs, ORY.
This package also made 474rwhp/429rwtq through a 2003 Z06 with Stock LS6 Intake, Stock Throttle Body, Mez Elec Water Pump, Borla Stingers, Kooks 1 3/4" with OR X-Pipe.
TTP Stage 3R Equalizer Heads/Cam Package
TTP AFR 225cc CNC Heads with Dual Springs, Titanium Retainers - Finish Ported/Polished by TTP (Milled to 63cc)
SVO 30lb Injectors
Flycut Pistons
(2x) AIR Gaskets
Installation
$5499.95 Turn-Key (Add $100 for Corvettes)
We have everything in stock ready to schedule appointments immediately.
Options:
We just finished up results on a 2002 Z06. Here is the mods list and power from the 3R package:
TTP Stage 3R Equalizer Package, LSX 90mm Intake, NW 90mm T/B, Mez Electric Water Pump, ASP U/D Pulley -- Full Belts, TPIS LTs with CATS (Hurting the car greatly), 19" IForged Rims
491rwhp/421.3rwtq
Old Mar 28, 2005 | 12:07 PM
aliwantsnss's Avatar
Give Dave at Cartek a call. Remember, price isnt everything, and you don't want to skimp when it comes to this stuff. I have learned that lesson already....
Old Mar 28, 2005 | 12:57 PM
Phil99TA's Avatar
Another vote for Cartek :thumbup: The results speak for themselves
Old Mar 28, 2005 | 06:47 PM
Jersey_TA's Avatar
Old Mar 29, 2005 | 01:28 AM
LS1LT1's Avatar
Originally Posted by Jersey_TA
