TTP Stage 3 Equalizer H/C Package Avail - Immediate Appointment
Had a cancellation today for one of our TTP Stage 3 Equalizer Heads/Cam packages. We can bring you in immediately to start work, the heads are already finish/port polished so everything is ready to go on.
F-Body -- TTP Stage 3 Equalizer Heads/Cam Package
TTP AFR 205cc CNC Heads with Dual Springs, Titanium Retainers - Finish Ported/Polished by TTP
TTP Equalizer V.3 Camshaft
TTP Hardened Chromoly Pushrods
Rollmaster Double Roller Timing Chain
SVO 30lb Injectors
GM Steel Headgasket Kit
(2x) GM Headbolt Kits
(2x) AIR Gaskets
(1x) EGR Gasket (If needed)
GM Timing Cover Seal
GM Timing Cover Gasket
(2x) GM Waterpump Gaskets
Installation
LS1 Edit Full Custom Dyno Tuning (Part throttle, wide open throttle, custom timing map, removal of engine codes)
$4699.95 Turn-Key
Options:
LSX 90mm Port Matched Intake Manifold with FAST or NW 90mm Throttle Body - $1250 Installed
Meziere Electric Water Pump with Relay - $600 Installed
Kooks 1 3/4" LTs with 3" ORY - $965 Installed (Add $260 for Cats)
TTP Stage 3 Equalizer Package Results:
This package just made 482rwhp/418rwtq through a 2002 Camaro M6 with LSX 90mm, Mez Electric W/Pump, 4.10 gears, SLP Loudmouth, Kooks 1 3/4" LTs, ORY.
This package also made 474rwhp/429rwtq through a 2003 Z06 with Stock LS6 Intake, Stock Throttle Body, Mez Elec Water Pump, Borla Stingers, Kooks 1 3/4" with OR X-Pipe.
SVO 30lb Injectors
(2x) AIR Gaskets
Installation
$4699.95 Turn-Key
Options:
