Eastern Members CT, DE, NH, NJ, NY, MA, ME, MD, PA, RI, VT, VA, WV
hooking problem??
Old May 4, 2005 | 07:14 PM
chevytat2's Avatar
Default hooking problem??
problem?
Old May 4, 2005 | 07:31 PM
bspz28's Avatar
Looks like you need more power so traction will become a problem again lol
Old May 4, 2005 | 07:39 PM
chevytat2's Avatar
its making good power now though
ESP heads and cam ls1 edit 404 rwhp 475rwtq
Miller Race Cars suspension(local guy)
he also did my complete exhaust system and roll cage
th400 install and 12 bolt rear
best run was 12.03 @117.34 first time with this setup at the track
Old May 4, 2005 | 07:40 PM
bspz28's Avatar
Sweet . car looks like it leaves hard good luck with it
Old May 4, 2005 | 07:41 PM
chevytat2's Avatar
thanks
Old May 4, 2005 | 08:46 PM
Slowhawk's Avatar
LS1Tech Sponsor
More power or more converter.
Old May 4, 2005 | 11:00 PM
Speedy0009's Avatar
Nice. . . I will agree. . . More power!!
Old May 5, 2005 | 12:03 AM
chief455's Avatar
ESP heads and cam ls1 edit 404 rwhp 475rwtq ls1 edit
what was your best 60'?
looks like a tight launch....
Old May 5, 2005 | 04:52 AM
chevytat2's Avatar
best that day was a 1.79 first time at the track with this car
Old May 5, 2005 | 05:13 AM
WJ SOM SS's Avatar
Air pressure looks real, real low...How was the ride on top? WJ
Old May 5, 2005 | 08:16 AM
Noyzee's Avatar
8 second mod
looks good
what converter is in it?
Old May 5, 2005 | 11:42 AM
chief455's Avatar
I had that time on drag radials - 15 psi
I would think a 1.5x with a Pro Stock slick wrinkle like that.(which you really don't want)
I agree now - more converter or/and more power. The suspension looks like it's working
Old May 5, 2005 | 11:49 AM
Noyzee's Avatar
8 second mod
the power is there, 400 threw a th-400 is good power. the car is probably heavy and a little more converter should do it.
Wheels went in the 11's no problem with his setup and it was around 400 rwhp
Old May 5, 2005 | 03:52 PM
02 Camaro SS's Avatar
How is the torque that much higher than the hp? Ususally it's the other wat around with heads/cam.
Old May 5, 2005 | 04:11 PM
Fred99Z28's Avatar
What size converter? I expected to see light under that left front tire the way the tires were wrinkled. I'd like to see that car launch with a 3500 stall. Power is fine. Torque is awesome. 1.6 or better 60's should be all day the way it hooks. That 12.0x would easily be in the 11's with a 1.6 short time.-Fred
Old May 5, 2005 | 06:00 PM
chevytat2's Avatar
yeah that was the first time at the track with this set up
its a 32-3400 converter from hughes ESP
tire pressure was around 15 psi top end was fun
with driver car weighs like 3750-3800 shes a heavy weight
my harlen 2 step isnt working so i was trying to hold it at like 3-3500 rmps and launch on the t-brake and wheni let off the t-brake switch the car jumped and my brain forgot to tell my foot to floor it so in the video you can watch it jump the bog then take off thats why the 60ft is crappy
Old May 5, 2005 | 07:26 PM
Krazy98Z28's Avatar
Is that a full slick, we tend to run full slicks at 10psi with screws, my buddy hits 1.3s all day on a 3,000 launch on the footbrake with 540RWHP
Old May 5, 2005 | 07:28 PM
chevytat2's Avatar
yeah a full slick
Old May 6, 2005 | 11:54 AM
Noyzee's Avatar
8 second mod
the t-brake is there so when you get to the line, hold it to the floor, green, snap your finger and hold on!!!
Old May 6, 2005 | 03:03 PM
chevytat2's Avatar
yeah but without the 2 step the car floored will be taching out you need the rev limiter
