Eastern Members CT, DE, NH, NJ, NY, MA, ME, MD, PA, RI, VT, VA, WV
First time at NED
Old Oct 25, 2005 | 11:16 AM
stangman_nb's Avatar
Heating street tires actually works to your disadvantage. By heating up a street tire you are actually making it oily which in turn makes the tire slip more. Kind of the exact opposite of a racing tire.
Old Oct 25, 2005 | 12:17 PM
Slowhawk's Avatar
LS1Tech Sponsor
Wanna bet
Old Oct 25, 2005 | 12:19 PM
badpewter-z's Avatar
LS1TECH Sponsor
got hot and sticky roll through the rubber from other tires and it sucks it up for added traction
Old Oct 25, 2005 | 12:20 PM
Are you refering to regular street tires or "dot" approved drag tires? Obviously not having the experiance you have I may be off on this, but from my personal experiances, especially with Z-rated tires, this is what I have found.
Old Oct 25, 2005 | 12:21 PM
Nautilus's Avatar
I've noticed a huge change in the amount of traction I get at the track. I used to just give tham a quick burn to clean them off, but after experimenting, I've noticed that if I get a good burnout in the tend to stick much better. I've dropped my 60' times by 2 tenths. Thats not all in heating up the tires, but it sure as hell hasn't hurt my times either.
Looks like I was referring to street racing and you guys are referring to the track. Hence different angles on the same topic.
Old Oct 25, 2005 | 01:11 PM
Slowhawk's Avatar
LS1Tech Sponsor
If you are driving around the street and come up onto a race,there is no need to heat the tires because they are already hot from driving.Now if your hanging in a parking lot and then line up it is good to do a good burnout and roll it atleast 50'
Old Oct 25, 2005 | 01:37 PM
Hmmmmm never thought of that.....learn something new every day.
