Eastern Members CT, DE, NH, NJ, NY, MA, ME, MD, PA, RI, VT, VA, WV
Tool is done.
Old Feb 9, 2006 | 04:52 PM
davered00ss's Avatar
Moderator
Default Tool is done.
First attempt at welding.
Old Feb 9, 2006 | 04:54 PM
Moderator
Not showing the back, where my welds are.
They are not pretty.
Old Feb 9, 2006 | 11:39 PM
badpewter-z's Avatar
LS1TECH Sponsor
cmon dave we wanna see both sides cant be that bad .
not to bad though unless there just sitting there not welded yet
Old Feb 10, 2006 | 12:57 AM
Nasty350LT1's Avatar
So, what is the purpose of this "Mechanical Marvel" ?
Old Feb 10, 2006 | 05:22 AM
JL ws-6's Avatar
Race your car!
To stop crank from turning when removing crank pulley. Doesn't look bad, I assume that's for the stock pulley... doesn't look like it will do much with an asp or other u.d. units. Doesn't look bad though.
Whold trick to welding is to never stop the welder while actually doing work, and a good steady hand. I haven't done any in a long time, but whenI was playing around with one years ago.. that is what I found.
For what it's worth, a good wire fed mig is way easier then an arc, and weldign alum. is a real pain to do... at least that's what I remember.
Old Feb 10, 2006 | 09:41 AM
RealQuick's Avatar
Come on Dave, lets see the welds. If you are using real mig (gas) the most important ting is havig enough gas, then having the correct power/speed, then the steady hand.
Old Feb 10, 2006 | 05:16 PM
Moderator
Here they are.
Old Feb 10, 2006 | 06:06 PM
hondo's Avatar
thats not bad for the first time, your using flux core it looks like?
Old Feb 10, 2006 | 06:39 PM
JL ws-6's Avatar
Race your car!
That's not terrible... I wouldn't be too ashamed of that. if it was your first time... that's actually decent. I have seen alot worse... like my own the first time... but then again, I was 15, and a steady hand wasn't even an option
When making your own tools... #1 the tool needs to work. Anything after that is a bonus.
Old Feb 10, 2006 | 08:09 PM
Moderator
Couldn't see **** with the welding helmet on.
