Eastern Members CT, DE, NH, NJ, NY, MA, ME, MD, PA, RI, VT, VA, WV
Oil to use to break in.
Old Jun 10, 2006 | 04:39 PM
1slowls1's Avatar
Default Oil to use to break in.
I know this has prob been beat to death but I was just wondering what kind of oil to use when I break in my new set-up?? I usually run mobil1 syn clean 5k, do I use a reg non syn oil to break everything in or should i just go ahead and use the mobil1 syn ??? Everything is in my sig.
Old Jun 10, 2006 | 04:47 PM
BrentC5's Avatar
When I was breaking in my motor Slowhawk said to use reg oil for first 1k or2. This seats the bearings. Then switch to the synthetic of your choice.
Old Jun 10, 2006 | 04:48 PM
1slowls1's Avatar
ok so just any non syn oil will do then?
Old Jun 10, 2006 | 05:00 PM
Noyzee's Avatar
8 second mod
buy a decent 10-40 oil, and a decent filter. put it in, run the car for 5 minits or so, shut it down, change the oil/filter, put basic oil in again, dyno the car or drive it for a hundred miles or so, change it again, then go 1k or so and change it again if you want this is the time to go to synthetic.
Old Jun 10, 2006 | 05:41 PM
ace68's Avatar
I think you ment to say rings?
Old Jun 10, 2006 | 08:16 PM
98Z28MASS's Avatar
wait is this just after a cam and heads install? If so id switch to a 10w-40 synthetic with a good filter. Im running 10w-40 amsoil and amsoil filter and it runs great. Unless its a new engine I dont think you need to change to a regular oil over a synthetic.
Old Jun 10, 2006 | 08:42 PM
BrentC5's Avatar
woops.
Old Jun 10, 2006 | 08:54 PM
ArrestMeRedZ's Avatar
I like to use dino oil with a new engine for the first few changes. I monitor the oil usage very closely. When it essentially stops burning oil, the next change I go to synthetic. For my LS1 Camaro, that ended up being after the third change (I used 500 miles, 2000 miles, and 5000 miles on the clock for changes). It sealed up right after the 5000 mile change, and I switched to syn the next change. I think it took so long because it may have had Mobil 1 originally from the factory.
I like Castrol GTX for break in. It's a high performance dino oil that is tough to beat.
Old Jun 10, 2006 | 09:36 PM
68ss_00ss_87_95's Avatar
i used regular 10w-30 or 10w-40 for my first 2 oil changes...ill go back to synthetic on my next 1 probably...
