Eastern Members CT, DE, NH, NJ, NY, MA, ME, MD, PA, RI, VT, VA, WV
clutch
Old Sep 27, 2006 | 09:16 PM
'02 SLP#686's Avatar
Again... Spec 3x for 10K plus miles in and out 4 times. 25+ track passes, multiple burnouts, beach traffic, etc... still fine
Old Sep 29, 2006 | 02:24 AM
INMY01TA's Avatar
I wouldn't put a Spec in my car. Mcleod singal kevlar here for about 4 years now. No problems.
Old Sep 29, 2006 | 11:12 AM
98hardtopSS's Avatar
i recently just put a centerforce in mine and it made a huge difference over the ls6 clutch/flywheel i had previously. the ls6 slipped bad especially when shifting into 2nd but the centerforce has no slippage at all. the trannys are very easy to take out as long as you have a long extension for the top bolts. i also put a fidanza flywheel in and it revs very quickly, it may even be too light. the person who owned the car before me put the flywheel on or had someone do it and they didnt use the right bolts, this resulted in two bolts backing out and wedging between the clutch and flywheel, it was a bad day....so make sure you order new gm bolts if you change the flywheel, they come locktited already and obviously fit perfect, a deep socket and a quarter inch ratchet does fine for bleeding as well.
Old Sep 30, 2006 | 06:18 AM
The Mcleod peddal was too hard for me - I like a clutch that feels more on the stock side for the pedal.
