clutch
As far as doing the job, having a lift REALLY helps. I did one with a lift, the only trick was bleeding the clutch, but we used a coolant pressure tester, worked mint.
If you dont have a lift, buy the parts and pay a good tranny shop to do it.
much smoother then spec. im going to say for anything under the 450 rwhp mark these clutches are great. after that id go to spec.
i can do a clutch in a few hours. faster if i skip the beer. lol i have a lift tho and ive done probably 20 or so clutches so it goes pretty smooth. if i didnt have the lift, id let some one do it for me.
DEZ installed it the first time. I had it in and out severl times since - not a single problem. Did it EVERY time without a lift. Hardest pert is the stupid tranny to bellhousing bolt that holds the breather tube - hard to get to. If you've done one before, in any car, you should be ok with this one.
