10$ item- big help!
Then-
I had to replace the grommet for the filler tube, so while I had the tank down, decided to replace a $10 dollar item:
It had some rust and even with the right fuel line release plastic tool it took some work.. it even had a bit of a kink- nothing much.
Filled the car back up- same 93 Octane stuff- and whoaaaaa!!!!!!
IDLE is now almost rock steady, despite the cam(s) and othe mods!
I nailed it in 1st gear and it fried the Kumho's to a crisp!!!!!!
I guess the moral of the story is.. change you fuel filters every so often!
The filters are usually a paper material and not impacted by ethanol. What you need to watch is the particulates in the gasoline.
