Eastern Members CT, DE, NH, NJ, NY, MA, ME, MD, PA, RI, VT, VA, WV
wtb
Old Jun 17, 2007 | 09:01 PM
peterock98's Avatar
Default wtb
Prothane motor mounts with or without the clam shell.
Old Jun 18, 2007 | 02:56 AM
LS1LT1's Avatar
Red face
Isn't that what they use to fire BBQ grills? j/k
ttt for ya Pete
Old Jun 18, 2007 | 06:48 AM
peterock98's Avatar
There called steamers lol.I went to cartek last week and Julio turned off the knock sensors. My y pipe is banging & it's so bad I don't want to drive the car.Maybe the poly mounts will stop the movement.
Old Jun 18, 2007 | 07:23 AM
The Alchemist's Avatar
UNDER PRESSURE MOD
I picked up mine at Pepboys for around $20 a peice if I remember correctly. You will need to re-use the outer shells which takes some modification, but isn't difficult to do. You simply drill out the rivets holding the two halfs together, then use the supplied bolts to bolt it back together. I've done both of mine and it made a huge difference. My y-pipe is tucked up about 1.5" from my floor board and no banging at all. I need to get under there and re-install the poly trans mount one of these days to get rid of shifter shake now.
Old Jun 18, 2007 | 07:26 AM
peterock98's Avatar
Ok kool i'll check pepboys
Old Jun 18, 2007 | 02:50 PM
2MCHPWR's Avatar
pete you ugly dog. do you have a poly tranny mount already? autozone sells them in stock usually. and if you get the poly motor mount, you only need one side, especially if you have poly tranny mount as well.
Old Jun 18, 2007 | 03:25 PM
peterock98's Avatar
It lives where u been hiding,I thought your wifey barred you from using the computer.Did you ask if you could post
