heater core removal
You need to remove the glove box, just a bunch of screws and bolts. Disconnect the coolant lines from the engine bay (probably the biggest PITA), also there is a black plastic clamp, in the middle of the lines there is a bolt that clamps it all down. As long as you can grab the core from the dash after the glove box remove, the lines disconnect and the clamp on the hard line it pulls right out.
