Eastern Members CT, DE, NH, NJ, NY, MA, ME, MD, PA, RI, VT, VA, WV
Engine dyno in CT ?
Old Sep 10, 2007 | 08:49 PM
Mrbowtie26's Avatar
Default Engine dyno in CT ?
Well it looks like im going to pull my newish aluminum block out to have it tig welded where the starter bolt hole threads broke :/ While I have it out is there a good place i can bring it near the west haven area to put the motor on the engine dyno ? It's a aluminum 402 block with AFR heads, fast 90/90, and 42 lb injectors. Not sure what they use on the dynos to tune the motors as far as ignition etc... but i would assume they have the equipment to dyno this combo.
Thanks
Ron H.
Old Sep 10, 2007 | 11:09 PM
Mrbowtie26's Avatar
ttt for the night. Goodnight all
Old Sep 11, 2007 | 04:37 AM
INTENESS's Avatar
Nice setup I have pretty much the same setup,Eastside performance is in conn give them a call they will take care of you ask for Sean the # 203 269 1539
Old Sep 11, 2007 | 06:08 AM
BlackScreaminMachine's Avatar
Internet Mechanic
I do know Carlquist in Watertown has a "Engine" Dyno.
Old Sep 11, 2007 | 06:55 AM
Mrbowtie26's Avatar
Ok thanks for the reply's
Old Sep 11, 2007 | 07:44 AM
Specialized's Avatar
Kehl Tech in Northford.
Kehl Technologies is what you might find them under in the phonebook.
Also: Andy's Automotive Machine in Plainville, CT.
Neither of these two places are site sponsors altough Kehl Tech builds motors for Eastside. I know for sure neither has a standalone setup to be able to dyno a ls(X) motor on either. You would need to get your own controller: BIGSTUFF3, Painless Standalone, etc.
Old Sep 11, 2007 | 04:20 PM
Mrbowtie26's Avatar
Does any of the above dyno's have a stand alone setup to dyno an LS based motor ?
Old Sep 11, 2007 | 04:45 PM
Read x2
Old Sep 11, 2007 | 04:56 PM
Mrbowtie26's Avatar
Read x2
I was talking about all of the dyno's mentioned in the above posts not just yours thanks
Old Sep 11, 2007 | 05:06 PM
thechef's Avatar
Moderator
i dont know of anywhere around here that is equipped to dyno the lsx engine, it will be cheaper and easier to dyno and tune it on a chasis dyno and not to mention probably cheaper
Old Sep 12, 2007 | 01:56 PM
9T9BlueTA's Avatar
SLP is 3 hours away. That may be your best bet for a shop that has an engine dyno with everything you need for an LSx.
Old Sep 12, 2007 | 02:18 PM
massls1guy's Avatar
I think Golen Engine in Hudson NH has an engine dyno. I saw some nice LSX engines on stands when I was there last.
Old Sep 12, 2007 | 06:13 PM
Agreed.
