Eastern Members CT, DE, NH, NJ, NY, MA, ME, MD, PA, RI, VT, VA, WV
Need to replace front speakers
Old Jun 11, 2008 | 08:16 PM
Z28Red01's Avatar
Default Need to replace front speakers
My front speakers have most likely crapped out, the mid-range is gone. Anyone get me and install new ones around 08061? I got a quote and the guy wanted $80 each and 3 hours install, anyone do better?
Old Jun 11, 2008 | 09:15 PM
Blackbirdws6's Avatar
Sounds on the high side. Took me about 1.5 hrs to get both front speakers replaced doing it for my first time. Wasn't all that bad really if you want to attempt it.
I realize this doesn't help much but if anything, the labor time sounds high just for replacing a couple speakers. Any re-wiring or other things being installed?
-Brian
Old Jun 11, 2008 | 09:20 PM
ULTIMATEORANGESS's Avatar
i just ordered a replacement from gmpartswarehouse for about $65 shipped.
Old Jun 11, 2008 | 09:34 PM
Z28Red01's Avatar
No, I was just checkin on here cuz the dude sounded like he was trying to get over on me. For the most part the hardest part is taking the door panel off I mean honestly it cant take to disconnnect and reconnect some wires.
And for the site I might just do it myself at this point for 1/3 less.
Old Jun 11, 2008 | 10:00 PM
Formula413's Avatar
Shop around for the speakers, GMpartsdirect, eBay etc., should be about $60. Changing them is easy, don't pay someone to do it, it's not hard. Do some searching for a writeup on removing the door panel. You will be glad you did it yourself.
Old Jun 11, 2008 | 10:09 PM
Z28Red01's Avatar
Ya I've removed the panels before when I had to replace the window motor on my drivers side which was the worst.
Old Jun 11, 2008 | 10:12 PM
razorclaw99's Avatar
I just bought 4 aftermarket speakers with a headunit..If you dont want to do that, just get 2 oem ones from gmpartswarehouse.com and do it yourself. Should be no more than 1.5-2 hrs labor for both if you must go somewhere..
Old Jun 11, 2008 | 10:22 PM
Z28Red01's Avatar
Weird every time i try gmpartswarehouse.com i get a error message.
Also where are you guys finding these at $60-65, I just looked on eBay and they are $105-115 each
Old Jun 11, 2008 | 11:12 PM
realmendrivev8s's Avatar
If they know what they are doing it should take less than an hour. I could change both door speakers in my camaro in like 30 mins, but that is because I did it about 100 times.
Old Jun 12, 2008 | 10:46 AM
DannoWS6's Avatar
I put Infinity Kappa 62.7i in my bonneville. They are 2ohm rated and better than stock. I think the same size fit's in your car. You can buy em' on Amazon or something.
Old Jun 12, 2008 | 04:31 PM
Formula413's Avatar
These should be the right ones...
http://cgi.ebay.com/ebaymotors/Camar...1V#ht_2561wt_0
