Need Baer Eradispeed rotors turned...
Anyone know of a place that will turn them. they are slotted and drilled and so far I have called tire kingdom and they said they wont turn them. any help would be appreciated.
thanks
thanks
I have tried to turn slotted and drilled rotors before and never had any luck turning them! When the bits drag accross and begin to cut into a slot or hole it chatters then snaps the bits.
Even cutting them .001" at a time it tears the bits up.
To my knowledge everyone I've talked to has the same luck BUT there has to be some way to true them up. Although I would think that the whole purpose of the slots and holes would be that so the rotors won't warp!
i am hopping someone knows how too. the drivers side rotor is fine. I get a hell of a squeaking noise out of the passenger side one and I cannot turn the wheel freely once I get everything bolted up in place. I get no pulsing just the noise. I checked the hub and it turns freely with no problem. so the next thing I thought would be the rotor.
I have bigger issues now. after putting it all back together the passenger side rotor sticks. it has been doing this ever since I got the rotors I just figured they needed to be turned. so I purchased a new caliper and I test fitted it with no success. it is like the rotor is too thick. any info would be greatly appreciated.
thanks
Wesley
thanks
Wesley
They weren't still under warranty? I had a set of Decelarotors, they had a 3 year warranty, they cracked out from the drilled sections. Went to Autozone, stated you would hope Baer would have made a better product, got my new set and ebay'd them, went for enough to pay for my Brembo blanks and HPS pads.
![Icon Lol](https://ls1tech.com/forums/images/smilies2/icon_lol.gif)
what I found out is that once I put the new rotors on the caliper was sticking. well the caliper bracket was slightly bent. not enough that i could see but it was 1.5mm off causing the caliper to stick. so I went to napa and ordered a caliper and caliper bracket set for $55.
They weren't still under warranty? I had a set of Decelarotors, they had a 3 year warranty, they cracked out from the drilled sections. Went to Autozone, stated you would hope Baer would have made a better product, got my new set and ebay'd them, went for enough to pay for my Brembo blanks and HPS pads.![Icon Lol](https://ls1tech.com/forums/images/smilies2/icon_lol.gif)
drilled and slotted don't really offer that much in terms of performance. You are losing surface area, more surface area = better braking. Just go get yourself a set of blanks and throw them on there instead of wasting your time with these.
