GM High-Tech needs FL cars!
![Thumbs up](https://ls1tech.com/forums/images/icons/icon14.gif)
GM High-Tech Performance is looking for YOU!
We need more Florida based cars for features! (Since we are based in Tampa)
So, here are the guidelines...
Post up 1-3 pictures of your car (must be late model GM EFI) in regular, internet resolution.
Include a link or brief mod list.
Please note, we will contact you FIRST, so please don't PM me and ask if we picked you yet. We have hundreds of readers submit pictures (which is really awesome) so it takes time to go through all of them. If we like your picture/car we will get in touch with you to get more information to meet up for a photo-shoot.
In case you are unaware, there is no cost for you (meaning no money is being exchanged here!) We just want to see your car!
Lawyers note: All photos posted in this single thread are presumed to be for publication and GMHTP reserved the right to edit accompanying descriptions.
Let's see what you got!!
Cam
Comp Magnum Pushrods
Comp 918 Valve Springs
F.A.S.T. 90 MM Intake Manifold
Nick Williams forged 90 MM Throttle Body
SLP Air Lid w/ K&N Filter
180* Thermostat
Pacesetter Coated Headers
Off-Road Y pipe
Corsa 3" Exhaust
Stock Bottom End/Heads
Front and rear drilled and slotted rotors
KYB AGX Adjustable Shocks
SLP Diamond Sub-frame Connectors
SLP Driveshaft Safety Loop
Heavy Duty Panhard Bar
Heavy Duty Torque Arm
Heavy Duty Front and Rear Sway Bars
Heavy Duty Rear Control Arms
Tower Brace
Brake Line Lock
Short Throw Shifter
Centerforce Dual Friction Clutch
Moser 12-Bolt Rear with 4.10 Gearset
Car: 2006 Lexus IS250 (Location Jupiter, FL)
Engine Block: 2001 LS1 three pass honed to 3.905"
Pistons: Mahle LS1314905F04 Forged Pistons w/ Rings
Crank: Stock LS1 ground .010" under
Connecting Rods: Stock LS1
Rod Bolts: ARP 134-6006
Heads: 241 Castings - DIY Ported and Polished
Intake Manifold: LS6
Injectors: 28 lb Injectors from an LQ4
Throttle Body: Smoothed Stock LS1
Intake Valves: Manley Race Series Stainless Steel Valves
Valve Springs: Trick-Flow TFS-16918-16 Pacaloy Beehive
Pushrods: Stock
Rocker Arms: Stock
Camshaft: Trick-Flow TFS-30602001
Timing Gear: Trick-Flow Dual Chain
Clutch: LS7 Clutch and Flywheel
Transmission: T-56 fully rebuilt by Astro Performance
Shifter: MGB F-Body Shifter
Oil Pump: Melling High Pressure
Oil Pan: Modified Corvette LS2
Power Steering Pulley: Turn One Billet Aluminum Pulley
Rod and Main Bearings Bearings: Clevite
Camshaft Bearings: Sealed Power
Fuel Pressure Regulator: Aeromotive 13129
Holley LS Fuel Rails
Holley HP EFI, ECU And Harness Kit
Spark Plugs: NGK Iridium IX
Wires: MSD
Exhaust:
-Hooker LS Cast Manifolds
-Custom Flowmaster 2.5" Stainless U-fit Kit
-Magnaflow X-pipe
-Borla ProXS Mufflers
-Magnaflow 4" Tips
![](http://i1288.photobucket.com/albums/b486/bepstein28/LS1%20Swap%201/10394153136_20fe518cdc_o_zps3d25e2a5.jpg)
![](http://i1288.photobucket.com/albums/b486/bepstein28/LS1%20Swap%201/10394143226_f9ec038a15_o_zps58210d54.jpg)
Pushrods: Stock
Rocker Arms: Stock
Wires: MSD
Exhaust:
-Magnaflow X-pipe
-Magnaflow 4" Tips
![](http://i1288.photobucket.com/albums/b486/bepstein28/LS1%20Swap%201/10394254234_3986a2310d_o_zps518b1b33.jpg)
1998 Chevrolet Camaro Z28 (38k Miles)
Mods:
SLP Intake
SLP Smooth Bellow
VMAX Ported Throttle Body
Mike Norris Catch Can
SLP Strut Tower Brace
SLP Loudmouth II Exhaust
ECM Tuned
Z28 Racing Stripes
Slotted/Drilled Performance Brakes
American Racing Torq Thrust Offset Wheels
Mods:
SLP Intake
SLP Smooth Bellow
ECM Tuned
Z28 Racing Stripes
Here is my 2000 SS
Low mileage ls1
Stock bottom end ls1 with arp rod bolts.
Stock 241 heads with patriot dual gold springs and arp head bolts
236/240 cam.
New LS7 lifters, LS2 trays.
Raceronix 255 pump with hotwire and 30#SVO redtop injectors
Polished wieand intake with polished stainless ARP bolts
80mm professional products TB
Smooth bellow
Pacesetter long tubes, TSP ORY, Magnaflow catback, Electric cutout
Dual nozzle 150 shot nitrous kit with 2 bottles. 1 in spare tire the other in between rear seats, 1 bottle heater
Converted 6 speed to a built TH350 reverse manual valve body, FTI 4200 stall, TCI flex plate
Driveshaft shop custom aluminum driveshaft with cnc yoke
Moser 9 inch rear with locker/ 4.11s
Lakewood 90/10 shock up front
Comp engineering 3 way adj drag shock in back
BMR adj tq arm, BMR Adj PHB
Lakewood lca
Wolfe race craft anti-roll bar.
sub frame connectors
B/M stealth pro Rachet shifter fitted into 6 speed console
Custom black paint with Viper blue flames
15x10 prostars with Hoosier 27x11.5 in back
15x4 summit stars up front with new tires.
rebuilt front end with new bushings last year
Best pass so far 10.84@126
![](http://i56.photobucket.com/albums/g173/camaro00/Pre-Meet11_zps5ce2c61b.jpg)
![](http://i56.photobucket.com/albums/g173/camaro00/Justin14_zps2401559e.jpg)
![](http://i56.photobucket.com/albums/g173/camaro00/Pre-Meet17_zps0d8a8623.jpg)
Low mileage ls1
236/240 cam.
Smooth bellow
Lakewood lca
![](http://i56.photobucket.com/albums/g173/camaro00/2013-03-02_16-54-06_727_zps07c84ac5.jpg)
Finally got mine up even though I feel like I've already been way out done lol. You guys got some sick cars.
Mods in sig and bmr springs and tick master cylinder coming in 1-2 weeks as well.
![](https://ls1tech.com/forums/picture.php?albumid=30026&pictureid=105973)
