Florida Members Fun, sun and LS1's
Accurate Octane in Orlando
Old Dec 10, 2013 | 03:31 PM
Philip Pugeau's Avatar
Default Accurate Octane in Orlando
My car is dyno tuned for 91 octane. When I get even slightly bad gas, I can tell.
So far, the best and most consistent has been just about any Sunoco. BP sometimes, but they're not consistent, nor Mobil. Plus, I like Sunoco's cash vs credit discount.
Any other experiences out there?
Old Dec 10, 2013 | 06:52 PM
ec_nova's Avatar
it's not the octane, it's the ethanol content. Steer clear of any gas station that isn't top tier(wholesale clubs, walmart, racetrac, etc) because they get the "worst" gas. As far as the whole "10% ethanol or less" is concerned, it's horribly regulated. I took a fuel class up in Georgia and we went to 5 local gas stations and got a gallon of gas, then measured ethanol content. They ranged from 5% to 40%. There is no regulation stating WHEN they have to add the ethanol. My best recommendation is to find a gas station that works well for you, and stick with it.
Old Dec 10, 2013 | 06:57 PM
ec_nova's Avatar
also... if you are noticing the car running differently just because of gas(which can happen, but usually only really **** gas and only under WOT) then you either need to look at getting it retuned, or replace your oxygen sensors with OEM sensors. They are either tired and very susceptible to small changes in running conditions(i.e. bad fuel) or they are aftermarket, and have the same issue. just my $.02!!
Old Dec 12, 2013 | 12:37 PM
Well, the good thing is that the car never ran horrible, just a little pinging at WOT in the high rpm range. That's what I meant with bad gas. Realistically, the car still ran without too much of a hiccup. After shopping around a lot, I found Sunoco to be the choice for me. I try to stick with them as much as I can.
Old Dec 12, 2013 | 12:39 PM
Double take ---- I think I've seen that white Camaro driving around, if you drive it on the street. Some time ago on 436 and 17-92.
Old Dec 12, 2013 | 04:33 PM
ec_nova's Avatar
there's a good chance it was me. I live in lake mary but i venture all around. For the past few months it's been on black 18" c6 zr1 wheels
Old Dec 12, 2013 | 04:53 PM
Could be. It has really springy suspension, I can tell in the pic, and so did this other white camaro with big and skinnies.
Old Dec 16, 2013 | 05:56 PM
toplessHO's Avatar
you could go with non ethanol gas
several stations in area that have it.
see puregas dot org
Old Dec 20, 2013 | 07:31 PM
Thanks for the info. Funny you should mention it, I just heard about it today. Costs a little more, right? Which sucks. Hard enough to afford gas in a 15mpg DD. " If you want to play, you've got to pay...."
