Jacksonville - Need 460le rebuild
Rob aka Predator T/A is the man you want. i think he moved to orlando now but if you want the job done right hes the one to talk to.
https://ls1tech.com/forums/member.php?u=15238
You won't regret using him.
I used best trans on Nevada st, Marietta exit since 99', for a few work trucks, 700r-4, turbo 400's & recently the wifes fwd car. They were the first shop I got to do a 400 correctly to hold out to a large panel truck. Treated me fair.
No need to do a 6 speed 80 all you are gonna do is spin with the deep 1st gear if your making power over 600 do a 80e and be done with it its cheaper to build a 80 than a 60 for high power apps
+1 on the 80, grab a decent core out the yard, shift kit, good clutches and input sprag are just about all mine has done, if I remember correctly, and its holding just fine, I have put that same recipe into 2 different cars, no issues with either so far... and the turbo car makes 800 wheel....
Glad to know we have a decent trans guy local, I have heard nothing but horror stories around here, about the local trans shops....
Rob you got a line on converters too?
A built 80e with a 4340 input shaft will take most anything you are going to throw at it there are always Billet intermediate shafts and forward hubs and direct drums if you wanna get deep in the wallet but a good buuilt 80e with a 4340 shaft is good for 900hp with no probs
