Un-Fing REAL!!!!
So I give the guy $4300 and head back home. I have my buddy tagging behind me since I forgot my tag. All seems well at this point, been driving for 250+ miles at a constant 80mph, though I had a fun pull to 120. Well we're heading EAST back home to JAX and we hit I-10 and 441, around Live Oak,I think it is, and all of a sudden my buddy pulls along side me and screams, "YOUR CAR IS SMOKING!!!" At first he thought it was am patch of heave fog, but then the smell hit him.
So I pull over and my car looks as if it's on fire, under the hood; we open it up and let the smoke dissipate and all I see is Trans Fluid EVERYWHERE! I first thought it was oil, because it was all on the pass side, but it start to puddle under the pass door and it's red. Now it's 12 Midnight, we're still 100 miles from home and we just drove 550+ mile, for the day.
So I call my Allstate roadside and get a flat bed out there to pick it up. The guy shows up to my house about five minutes after we do. So he's unloading the car and needs to use a plank of wood under the pass tire to clear the bed and as the car is rolling back, the wood lifts and gets jammed into and under the bumper pushing it forward, now it is separated at the upper fenders on both sides. I call Allstate and they tell me to bring it up with the towing company so now I got to fix the ******* trans and Deal with a ******* retard of a tow company.
I'll reiterate.... UnMOTHERFUCKING REAL!!!!
Last edited by Whistler; Mar 17, 2014 at 03:57 AM. Reason: Don't curse in the title
well being that it's only been a few hours and it's now a sunday, I don't have any news to update with, but let me ask this...
The Pass side is the side that got drenched with Trans fluid. It's all over the Pass side wheel on the inside and outer side. Is there any type of line that could have ruptured on that side? Why was it all localized to the Pass side and nothing got on the driver side?
Here's is one thing i recall before it happened... the guy in front of me hit his brakes hard, which in turn coaused me to do the same. When i did that, i heard a strange little noise and it felt as if a vac line popped off or something; right after this, this is when my buddy pulls along side of me and tells me I'm smoking. Here's the thing though... the car was still in gear and I was still accelerating. save for that weird noise and sensation I felt, right after the hard brake, I didn't notice anything.
Could a line have popped or maybe the pump seal popped? Like I said, I was doing around 70mph give or take 5 or 10 mph and I did get spirited about an hour or so earlier, hitting over 100mph.
Prior to this, we had stopped numerous times and I smelt nothing, nor experienced anything strange. Up till it happened, it was literally SMOOTh sailing. I just don't get it.
As for the damage the fucktard did to my bumper, when removing my car from the flat bed. Now that I can see it in day light, there's a good 1/4 gap where the upper corner of the bumper meets the fender.
This is just BULLSHIT!!!! Unbelievable BULLSHIT!
If I remember correctly the trans cooler lines connect to the radiator on the passenger side. If one of the cracked or had a leak you might get fluid around that area.
When you looked was the trans dip stick seated? If a trans gets hot enough it can push fluid out the tube. This can be very dangerous. If the fluid gets on the header it can catch on fire.
How much trans fluid did you loose? Does the fluid smelled burnt? Is it red or brown?
Maybe a trans guru can chime in.
Tow company's have insurance for stuff like this. They will try to refuse and weasel out of it. Don't let them fix it themselves they will try to cheap it out. Many states regulate or license the tow companies so you might have some leverage there.
Good luck.
