Florida Members Fun, sun and LS1's
Power Steering Pump Headaches
Old Mar 9, 2015 | 08:50 AM
GTO_Cape's Avatar
Default Power Steering Pump Headaches
My stock power steering pump broke last year. They dont make that part as per Chevrolet so I had to get a replacement via autozone (refurbished). I installed that but was not running normally. Making a ton of whine and not really working properly. So I got that replaced and the new one makes the similar noises and is also not running normally. Where when you turn at a low speed the steering gets really hard and not smooth. Ive been dealing with things like this since mid last year and needless to say is getting to me now.
Im looking for assistance from my fellow Fort Myers/Cape Coral LS guys. Not sure if Im doing something wrong during the installation or not so I was wondering if anyone knows of a shop willing to get my pump intalled if I bring them the replacement? or if anyone knows of a mechanic that is willing to work on my car?
At this point I just want to get this fixed cause I must be doing something wrong during the install.
BTW this is a 2004 Pontiac GTO
Old Mar 9, 2015 | 02:15 PM
GTO_Cape's Avatar
Originally Posted by ragtopz28
Well my shop behind my house is somehow turning into a local LSx hot rod shop...I have a friend that is GM mechanic at Dixie Buick and is currently on workers comp leave. He helped me this past weekend do headers, exhaust and plugs on Uziguy18's car. PM me for possible help.
PM heading your way
Old Mar 10, 2015 | 07:21 AM
Jaysz28's Avatar
Active Streak: 30 Days
Is there a possibility that your rack is going bad???
Is all the air properly bled out of the system????
I dunno, I had ps whine in my car and it turned out to be the steering box itself
Old Mar 10, 2015 | 11:33 AM
GTO_Cape's Avatar
Not sure, its possible. Although everything was working fine until that first power broke. I did noticed a leak on the floor today. So that is a sure thing now
Old Mar 15, 2015 | 12:45 AM
GTO_Cape's Avatar
UPDATE:
So ragtopz28's friend replaced the pump with an Autozone Re-manufacture one and we dropped about 1/2 bottle of Lucas Power Steering pump stop-leak in it as well as the ATF stuff. The new pump doesnt make any noises and we did take the air out of the system by doing the turn wheel from lock to lock deal. Took the car off the ramp and drove it. That thing was a full arm work out. So I dont know if this pump might also be bad from Autozone since Ive heard great things about them (really not) or if there might be an issue somewhere else.
ragtopz28's friend is going to check at work and do some more re-search but the car at this time is almost undriveable.
Old Mar 15, 2015 | 12:43 PM
NitrOmm's Avatar
Originally Posted by GTO_Cape
UPDATE:
Take a look at the Turn One pump. I went with this a few years ago after having similar issues. It's made for the job.
http://www.qwikperformance.com/turn-one-steering.html
Old Mar 16, 2015 | 09:14 AM
GTO_Cape's Avatar
That pump looks good but it doesnt look like it would fit my car anyways. The LS1 pump from the camaros is a little different than the pump for a GTO.
GTO Pump: http://i.ebayimg.com/00/s/NzY4WDEwMjQ=/z/q8wAAOSwuMFUhMsQ/$_35.JPG
Old Mar 16, 2015 | 07:28 PM
Trevor.j's Avatar
I have replaced 3 pumps on 04 and 05 gto and having no issue. Sounds like air was trapped in the 1st one then just a bad pump from autozone. I am also in the cape let me know if you need anything.
Old Mar 17, 2015 | 10:21 AM
GTO_Cape's Avatar
will do, thanks
Old Mar 17, 2015 | 10:44 AM
chaney1974's Avatar
look online for GM rebuild kits for the pump they are under $20 and are available still I have used them many times with no problems.
