Florida Members Fun, sun and LS1's
Engine/Machine shops near Brevard
Old Jul 9, 2015 | 08:30 PM
xXSilencerXx's Avatar
Default Engine/Machine shops near Brevard
Anyone know of a good machine shop around brevard? A motor mount bolt broke off in my block. Being that it has 180k miles I've toying with the idea of having the whole thing looked at and possibly rebuilt while I have it out of the car, if there is a good engine shop around.
Also, I've never transported an engine before. Any tips of how to put it in a truck bed? I was thinking of building a wood frame to set it on and then strap it down.
Old Jul 9, 2015 | 08:47 PM
v8pwr's Avatar
Get a set of easy outs and you can do it yourself. Removing a broken bolt can be simple if you are careful. If not there are shops that can handle the task. If I wasn't so busy I'd do it for free.
Old Jul 11, 2015 | 08:16 AM
I have a set of easy outs, but the bit is not working when removing. The bolt itself appears to be too soft for the amount of forCE requite to back it out. The bit spins inside of it rather the bolt turning.
Old Jul 11, 2015 | 06:06 PM
v8pwr's Avatar
Did you tap the easy out into the bolt remnant or just try to push it in?
Old Jul 15, 2015 | 05:53 PM
Tapped it first with the other end of the bit.
