Looking for shops that drop the transmission pan
Little back story:
Trans started slipping while trying to go into 3rd. 1st and 2nd are ok and if I go fast enough in 2nd and manually shift into 3rd, the trans would shift into 3rd and likewise if I did the same for 4th. So the trans still has all the gears and still has reverse. I have a TCI deep transmission pan which has a nice drain plug on the bottom, so I drained the fluid (5 quarts) and the fluid was reddish brown but no burnt smell, still smelled like transmission fluid. I took off all the bolts around the pan but the pan wouldn't come off since it wants to stay mated to the trans itself. I have the filter and gasket already and called Jiffylube to see if they drop the pan. They said no, they only do fluid flushes (no thanks) and drain the 5 quarts which they charge 89 dollars for and I already did in 5 min for free with no mess.
So I put 5 new quarts in and ran it through the gears, still have everything and will test drive it tonight. If worse comes to worse, I'll change the fluid again in 2 weeks and keep doing so till the fluid comes out completely red till I'm able to find a place that can pull that pan off and change the filter.
Any recommendations? Thanks in advance.
Have you tried asking guys in the Fbody club or at gatherings if they want to do it?
Any mechanic shop, even a PepBoys should only charge you half hour labor. Pull into a gas station that has a mechanic and ask how much they'll charge. Or like Goodyear tire shops that have mechanics.
When I need to do little things just because I need a lift I pull into these places and offer them a $20.00 to lift my car for a quick little job that needs to get done. They usually go for it.....
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Thanks for the responses though.
He has been doing my tranny for the past 11 years or so. They last 3-4 years before they need a rebuild...and that was with my 427ci stroker and 500 RWHP going through it getting beat on almost every day. Thats a good 4L60E build.....
he charges between $500-$600...Parts and labor. He uses all the good upgraded heavy duty stuff. Don't really remember the parts he uses, but they are top quality aftermarket brands.
I would guess shipping on an Amtrak train would cost you $50.00 each way. Don't pay $1,500 to a tranny shop or race "tranny" shop....you will get the same exact tranny as my friend builds.
PM me if you want his contact info.
