Holiday Installed AFR Heads/Cam Packages @ NLP
Hey All,
We are offering heads/cam, installed special for the holidays thru Jan 18th. The installed price is $3995 plus tax and includes:
1510 or 1530 AFR 205 heads.
Comp XE or XER cam.
Comp moly pushrods.
GM gaskets and seals.
NGK spark plugs.
Professional install and full LS1 Edit dynotune.
Milling the heads for extra compression will add $100.
We are also offering parts packages through this time period also and it will run $2795 plus shipping as needed and applicable sales tax.
Comp XE or XER cam.
Comp moly pusrods.
GM MLS head gaskets.
GM head bolt kits.
GM exhaust gaskets.
GM valve cover gaskets.
GM EGR and AIR gaskets as needed.
GM timing cover gasket.
GM water pump gaskets.
GM timing cover seal.
GM crank hub bolt.
This pricing will fall into our next order from AFR due to ship in January.
Please feel free to e-mail or call with any questions or orders and we look forward to hearing from you. Happy Holidays to all.
Mike Norris
Comp XE or XER cam.
Comp moly pushrods.
NGK spark plugs.
Comp XE or XER cam.
Comp moly pusrods.
GM head bolt kits.
GM exhaust gaskets.
GM crank hub bolt.
Mike Norris
10 & 11 Second Club
Originally Posted by Mike Norris
225's are on the way Dave. Have a great Christmas and talk to you soon.
Mike Norris
Mike Norris
