Florida Members Fun, sun and LS1's
Where to go for transmission work?
Old Mar 17, 2005 | 09:13 PM
777's Avatar
777
Default Where to go for transmission work?
i need to know where to go for transmission work near ocala...i want to get new synchros and a steel 3-4 shift fork...tranny has near 100k miles and grinds 3rd and 4th often and is now occasionally grinding 2nd...and 1st can sometimes be a little difficult to get in but that's pretty rare...i've been quoted 1900 from a couple shops...and i've been told that labor should be near 250 not 1700...haha so if anyone know where to go please enlighten me
Old Mar 17, 2005 | 09:47 PM
Caveman's Avatar
10 & 11 Second Club
You should take it to Lamotta Performance in Orlando. Jake Lamotta is the best tranny guy around with M6(T56), he is a long time dragracer and knows his **** .
Old Mar 18, 2005 | 10:13 AM
777's Avatar
777
i'm kinda wanting someone more local...but who knows
Old Mar 18, 2005 | 11:38 AM
Flals1's Avatar
I'm not sure of anyone local to you but Next Level Performance in Altamonte Springs is worth a try.
Old Mar 18, 2005 | 01:44 PM
777's Avatar
777
$2000 is not my cup of tea that's one of the two places i have gotten quotes from...the other is revxtreme in tampa
Old Mar 19, 2005 | 09:34 PM
TPl92z's Avatar
I'd second Jake for a T56 rebuild. I've known a few people who have had them rebuild their T56s and T5s. Work was flawless, quick, and the bill was fair.
Old Mar 19, 2005 | 10:26 PM
Jpr5690's Avatar
what about for a 4l60e
Old Mar 21, 2005 | 10:27 PM
Caveman's Avatar
10 & 11 Second Club
There is no shop in the area(Florida) that does good work on 4L60 trannys. Next Level Perf. uses several good tranny builders, I have used Century Trans out of Houston,Tx for my tranny rebuilds every 3 or 4 years. Century, Rossler and FLP are probably the best to go with.
Old Mar 21, 2005 | 11:30 PM
Jpr5690's Avatar
so the flp stage 4 will be a good tranny for a big cam and 150 no2 car right ?
Old Apr 11, 2005 | 06:10 PM
raymond mckinney's Avatar
Tim meloy in land 'o'lakes I believe that's it, it's on the end on Dale mabry
Old Apr 16, 2005 | 01:06 AM
JimMueller's Avatar
Another vote for Jake Lamotta if you can't find anyone closer. He typically charges $250+tax for the labor, plus whatever parts you desire to have replaced/upgraded. He can order them for you, or you can have them drop-shipped to him. Busy guy, small shop. Definitely need an appointment.
NLP usually takes their M6's to Jake, btw.
Old Apr 16, 2005 | 09:53 PM
777's Avatar
777
well to be honest my tranny is basically shot...i will need a new 3rd and 4th gear for sure...i really need to find a new one or a used one and get it built...it's going to be crazy money trying to rebuild this one...
Old Apr 16, 2005 | 10:57 PM
redline2k's Avatar
Action Performance in Daytona had my redone. The labor cost 250.00 for a complete rebuild with the viper output shaft.
Old Apr 17, 2005 | 12:26 AM
distortion_69's Avatar
How do you know the gears themselves are bad? It's likely just a bad synchronizer assembly.
Peace,
Josh
Old Apr 17, 2005 | 11:17 AM
JZ'sTA's Avatar
Yeah I bet you probally dont need another case. Your tranny will probally be fine once you have it torn apart and rebuilt.
Old Apr 17, 2005 | 12:49 PM
Jpr5690's Avatar
action performance in daytona beach gets my vote.. their not really over priced and they seem to be honest nice people. ive had work done at daytona street and performance and they did a good job but they arent a real big gm place action seems more knolgeable in our cars
Old Apr 17, 2005 | 01:02 PM
LiquidSword's Avatar
Kenny Wells Performance off Michigan Street in Orl. I know of one he built with 15K on it FS. PM me for info.
Old Apr 17, 2005 | 06:37 PM
97blkz's Avatar
4l60e's stink! I have gone thru 4 , i just need to pony up and convert to an 80e.
Old Apr 18, 2005 | 11:49 AM
777's Avatar
777
Peace,
Josh
honestly i don't...but 3rd gear won't stay in half the time...i'll go to shift and it will go in...then i'll start letting the clutch out and it will pop out...some times i'll hold it there and it will make a popping noise then start grinding...but it happens about every 10 times i shift into third...dino at revx also said that i would have to get 3rd gear replaced at the very least...i'll prolly call up daytona and see what's going on...i can use it as an excuse to go to the beach...anyone have an idea on how much money this is going to cost...i've been quoted 2000-2500 from revxtreme...and about the same from norris...i haven't checked to much locally but one (i can't remember name) was about 2000 for the rebuild...is that basically what i am going to be looking at or is it going to be cheaper...i need 3-4 steel shift fork as well as the rebuild...
Old Apr 18, 2005 | 12:20 PM
Mike Norris's Avatar
Basically you are looking at $300-350 for the trans R&R, $250 or so for the trans rebuild labor plus parts, sealer and fluids. Parts can range from as little as approx $700 to $1500 or more if you want to get more exotic and use cryo treatments.
A average 3-4 shift issue repair is in the $1600 area approx with all labor and parts, but hard to say until you get the trans opened up. This includes new blockers, synchros, steel 3-4 shift fork, sealer, seals and fluids.
I have done up to $3000 builds depending on what is broke and what the customer is trying to do. Then of course there are the clutch questions as well as the hydraulics.
Hope this helps.
Mike Norris
