Florida Members Fun, sun and LS1's
Oil pressure
Old Mar 24, 2006 | 12:46 AM
GDM Z28's Avatar
Default Oil pressure
how much is too much? if you have high oil pressure would using a thinner oil be a bad way to try and lower it?
Old Mar 24, 2006 | 05:50 AM
Country Boy's Avatar
Senior Member
what do you consider high oil pressure?
Old Mar 24, 2006 | 01:28 PM
GDM Z28's Avatar
right now cruiseing when the temps are low my oil pressure is aorund 70-75 psi....when the temps go up a little more its around 65 or so.
Old Mar 24, 2006 | 01:29 PM
Senior Member
thats not bad really. Is it a stock LS1 and what weight oil are you using?
Old Mar 25, 2006 | 03:10 AM
GDM Z28's Avatar
its a heads and cam motor with a ls6 oil pump (04 gto bottom end). Im useing 5-30 or 10-30 i forgot which oil i used on this motor because i just got it running. i can check the bottles tomorrow.
Old Mar 25, 2006 | 11:41 AM
johnnytransam's Avatar
what if my oil reads 60 when i start the car but then goes down to 40 or lower? need to change the oil pump?
Old Mar 25, 2006 | 12:53 PM
GDM Z28's Avatar
thats how most cars are. which oil are you useing?
Old Mar 25, 2006 | 01:29 PM
1999TransamWs6's Avatar
You should be using 10-w30. And like I said im pretty shure your gauge is just messed up because of that needle.
Old Mar 25, 2006 | 05:15 PM
i just used penzoil 5w-30, so i guess i should change to 10w-30?? any suggestions on what brands?
Old Mar 26, 2006 | 02:44 AM
GDM Z28's Avatar
what does mike give you from the dealership? i got a case from him and i think it is 10-w30. also i think the gauge is fine.
Old Mar 26, 2006 | 12:09 PM
Mike didnt give me anything I bought it from walmart.
Old Mar 26, 2006 | 05:44 PM
phoenix's Avatar
**** i am at 40 psi cruseing around and 30-35 idleing
Old Mar 26, 2006 | 07:28 PM
Turo's Avatar
My car idles at ~45 and goes to around 60 when cruising.
Old Apr 11, 2006 | 02:01 PM
Last Call's Avatar
TOTM: January 2007
Mine is 65 at idle, and 80+ anything over 2500 rpms. I dont know where to look. I verified the pressure with a mechanical gauge and the pressure is 65psi at idle.
