87 buick turbo t WE4
i have a buick turbo t for sale,its the rare WE4 model,and its in great shape.here is the mods.the car has ran a best of 11.21@122 with a 1.88 60ft
$13500.00
Here’s a small list of what’s mostly done. The shortblock is basically a stock rebuild (cam, etc.)
PTE-52 TURBO
PRECISION TURBO & ENGINE FRONT MOUNT INTERCOOLER
42.5 LB INJECTORS
TERRY HOUSTON DOWN PIPE
MAX-EFFORT 16 POS. COMPUTOR CHIP
K&N AIR FILTER AND SOLID MAF PIPE
ADJUSTABLE FUEL PRESSURE REGULATOR
SCAN MASTER SCAN TOOL
PTS 9x11 3200 RPM STALL TORQUE CONVERTER
METCO SOLID ALUMINUM LOWER CONTROL ARMS
LAKEWOOD ADJUSTABLE DRAG SHOCKS
AIR-LIFT AIR BAGS
WALBRO 340 FUEL PUMP.
HOOKER 2.5" EXHAUST SYSTEM
MAGNECORE 10MM PLUG WIRES
AUTOMETER BOOST, TEMP AND OIL PRESSURE GUAGES
B&M TRANSMISSION COOLER
DIRECT SCAN SOFTWARE
DIGITAL EGT METER PURCHASED FROM PTE
ARP WHEEL STUDS
ALKY KIT(methanol)
Here’s a quick rundown of what’s in the transmission.(2004R)
modified 13 vane pump
Larger boost valve
modified valve body AKA "shift kit"
Billet forward drum
Alto red band Blue clutches
billet overdrive planetary,trans. is fresh,not even in the car yet
And a few other minor mods like roller bearings, etc.,built by lonnie diers
$13500.00
PTE-52 TURBO
42.5 LB INJECTORS
AIR-LIFT AIR BAGS
ARP WHEEL STUDS
ALKY KIT(methanol)
Larger boost valve
Billet forward drum
