what oil are u running....
Explain?
I run a 20w50, but I run it for a reason
I used Redline now, but Im going to switch to RP because noone carries RL anywhere. I run a 20w50, but I run it for a reason
Anyways I never understood why people used 20w-50? When I worked at a lube center, it was always the crazy rednecks in their Exploders, Deathscorts, Taurass, V6 GM Trucks/SUVs, or just random people with like a Camry who wanted that ****. Can someone explain why?
I use a 20w50 because when I built my motor, I used a tab of a looser clearence on the bearings because I built it for a 200+ shot. If you build a forged motor with stock clearences and spray the **** out of it with thin oil, youre going to squish the oil from the bearings and risk burning them ultimally killing all the bearings.
I remember being nervous about the "0" in the GC 0w30, until Patman mentioned that it's actually a very thick 30 weight, almost a 40 weight. Definately thicker than Mobil 1 5w30 I used to put in.
i also run about 1 qt extra to help slosh.
I wouldnt either. I tried it and it rattled pretty bad. I did run with 10w30 stock.
We carry Amsoil and i would LOVE to run that stuff, but damn its expensive no matter what!
