Forged LS1 long block FS...
NEW Mahle forged pistons
NEW Callies Comp Star H-beam rods
NEW Eagle stock stroke crankshaft
New rod & main bearings
Cam bearings installed in block
(1) valley cover
(1) set of valve covers
(2) front covers
(1) rear cover
(1) C5 oil pan
(1) full set of rockers w/ bolts, etc
NEW crane lifters
NEW SLP dual roller t-chain
W2W ported LS6 oil pump
243 Casting 05' GTO heads w/ 9K miles, complete
NEW GM head bolts
Also included is almost every bolt you can think of related to the motor, lifter trays w/ hardware, crank pos. sensor, cam pos. sensor, knock sensors w/ knock sensor harness, oil pressure sneding unit, f-body motor mounts, starter w/ bolts, stock balancer, stock water pump, and anything else related that I find in my garage goes with it.
The motor needs assembly, the rods are hung on the pistons, the pistons have been fit to the bore, etc. I might have a stock cam lurking somewhere in the shop. But, other than a cam it lacks a few gaskets and assembly.
$3K FIRM.
WILL NOT PART OUT!
Sure you can. Price them out, and then add in all the extras. It's a damn good deal, and I'm already taking a loss. The crank was $900 alone, then factor in the rods & pistons, block, machine work, etc. Most LS1 shortblocks have used stock cranks and require you to send them a core. They cost between $2600-$3000 on average + shipping, core chareg, etc.
