Florida Members Fun, sun and LS1's
Help please
Old Aug 24, 2007 | 07:24 PM
VIPERXAVIER's Avatar
Default Help please
There is a round thing on the driver's side of my lt1 not the alt. no belt ran to it but it has cooling fins on the back of it what is that? any one know
To see it you have to take the air cleaner out and it's bolted to the right of the water pump
seems afordable in saint augustine fl forgot to bolt it back up I have no clue what it is but the car just blew 3 cooling hoses
Old Aug 24, 2007 | 08:07 PM
Ntimid8r7's Avatar
if it is black with a hose running to your air box it is the AIR injection pump. A wire harness should be at the bottom or back of it.
Old Aug 25, 2007 | 09:04 AM
OreoLt1's Avatar
It's the air pump. Sounds like a conincidence that you had hoses fail and found that the pump was not bloted up at the same time.
I'd check to see if the pump could have rubbed against anything and also check the condition of the hoses.
