Cam Install $'s
We are at 950 BTW for a full cam swap with springs, chain, pump etc, and 550 extra for a full tune using EFI live.
Figured I would add in on this thread seeing as it is about pricing.
I thought we were very high but juding by most post's we are around avarage or just a tad high of avarage. Whistler is way below avarage. I might let him change my next cam. HAHAHA
Jeremy
**** I am sending all my installs to Whistler. I cant do it for that. Overhead is a bitch.
http://www.mphparts.com/mm5/merchant...Category_Code=
Brand new Comp cam, Brand new set of Patriot Gold Spring's (Kit) and all the gaskets for the cam swap. All for 649.99. Then have Wistler do the install (probably for 400 as you already have gaskets) and you have a cam installed and ready for tuning for under $1100.00 That is a damn good deal.
Even if you want to add Pushrods, a new timing chain, and a ported oil pump and a UD pulley, we sell that whole combo for 1113.93 and then the install you will still be well under 1600 for everything.
Give us a call if you interested in a cam swap after seeing how cheep the process can be, and we will even cover shipping.
Add a tune and a set of LS6 ported Heads for a total WELL less than $3500 installed and you have 500-600 hp at the crank depending on the accompanying upgraded bolt-ons
https://ls1tech.com/forums/image.php...ine=1194732633
Free Cooler, Free shipping always, 2 year warranty Trans/Coverter combos, No Core or Core charge, $150 LS1 core buy back, All trans Dyno Tested to Be sure it works when you get it.Customer videos, Tech Thread, Open 7 Days a Week! Call or http://opi.yahoo.com/online?u=performabuilt&m=g&t=2
Click Banner for Website.Not Just Built.....PerformaBuilt!
