Timing Tuner and a few nitrous gadgets
https://ls1tech.com/forums/lsx-parts-sale/810491-timing-tuner-cheap-gm-fuel-tap-fittings-othere-stuff.html
Right now, I'm just saving money and doing the research. Daughter going to UF in the Spring, so, having to adjust priorities away from the car right now.
Either Way There Is Many Pros\cons To Both Personally I Wouldent Spray A 150 Shot On A 347 Hell Im Planning On A175 Shot For My Stock Bottom End.. When I Get Up To My Next Bottom End Im Gonna Try For A 2-3 Stage 300+ Shot
Either Way You Go You Will Be Fast.. Just Think Optimal Turbo Setup = Compression Change, Cam Change?, Converter Change
But It Would Be A Blast
