Florida Members Fun, sun and LS1's
drill mod?
Old Sep 30, 2008 | 11:34 PM
Art Vandaley's Avatar
Default drill mod?
Anyone in central FL that can do the drill mod? No longer have garage or space so not sure if anyone can help me out with this? PM me
matt
Old Oct 1, 2008 | 09:54 AM
stealth71's Avatar
Can you remove the master? It's easy after that.
Old Oct 1, 2008 | 01:22 PM
ALLMOTOR346CI's Avatar
Srry for a stupid question but wtf is a drill mod!??!?!
Old Oct 1, 2008 | 01:57 PM
72VenturaII's Avatar
Here is the write up for the drill mod:
http://www.installuniversity.com/ins...r_cylinder.htm
Old Oct 2, 2008 | 09:58 AM
Titanws6's Avatar
Matt, you can come by and use my garage and tools, I need to do this mod too. If anyone has experience, let em know, it would be nice to have someone there to "supervise" to make sure we do this right. Thanks
Old Oct 2, 2008 | 11:25 AM
FBodyPerformer's Avatar
Steve, make that 3 of us. Im starting to lose clutch pressure getting on it at high speeds. This might help it out?
Old Oct 2, 2008 | 11:28 AM
ttranssam's Avatar
GUYS SORRY BUT DONT WAST YOUR TIME...oops the caps was on but it did nothing. do the adjustable master mod...there a sticky on it...
Old Oct 2, 2008 | 11:52 AM
SnowmanWS69's Avatar
It helps alittle cause it does push more fluid. All you haveo to do is remove the line. Get a 1/8 drill bit. Drill down the middle of the line and clean it out and your done. I had an adj. master and took it off...did nothing waste of money.
Old Oct 2, 2008 | 01:35 PM
Titanws6's Avatar
So just disconnect the line from the resovior and the clutch and drill it out?
How long is the line, how long of a drill bit is needed?
I've seen the adjustable master from Tick Performance, looks really good, but like you said, waste of money right now.
Old Oct 2, 2008 | 01:51 PM
stealth71's Avatar
The line total is probably 24-30" long. There is a roll pin on the master side and a quick disconnect on the slave side. You are drilling the master side. I just lined the drill bit up next to the line and marked it with a piece of tape where to stop drilling. It's pretty simple.
You might also get something to help bleed the clutch. Might vac, power bleeder, ...
Old Oct 2, 2008 | 06:12 PM
kwiksilverz28's Avatar
I cut a hole in my tunnel with the trans out to make bleeding a 1 man job. Not sure how to get up in there without it. I just covered the hole after I was done, and you would have no idea it was there....
Old Oct 2, 2008 | 10:07 PM
I would take the whole line off cause it has plastic crap in it after you drill it. youll feel it go throw the ball then just stop.
