This might be a bad Idea, but.......
Old Oct 15, 2008 | 09:34 PM
  #81
1CAMWNDR's Avatar
Originally Posted by Pharm0r
Just throwing something out there....we could always mix and match exhaust manifolds couldnt we? to help solve the ac problem...
That is what we are saying. Truck passenger side non-EGR manifold on the driver's side pointing forward, and a C6 passenger side manifold on the passenger side pointing back. Then curve the "up pipe" around the location of the A/C compressor.
Old Oct 15, 2008 | 09:44 PM
  #82
NemeSS's Avatar
Originally Posted by Grr
you guys really should listen to me, get a impala ss front manifold and it exits right above the heater hoses and solves ALL the problems, no interference whatsoever with the A/C.
hmm.
ive never seen that manifold before, seems like it should fare well in design of a turbo system.
Old Oct 15, 2008 | 09:57 PM
  #83
ModularTurbo's Avatar
Someone post pics of these manifolds please, on the car if you can.
Old Oct 15, 2008 | 10:08 PM
  #84
1CAMWNDR's Avatar
Post #78 in this thread shows where these manifolds sit on the LS4 block, and with the front LS4 manifold facing forward on another block. It looks to have the collector right where the A/C compressor would go, but I have never seen an LS4 manifold in an F-body before.
Look at post #1 here :
https://ls1tech.com/forums/showthrea...ht=manifold+c6
There is a pic of a C6 passenger side manifold with a turbo up pipe that will curve around the A/C manifold. That one goes through a regular aftermarket K-member and then turns back in after passing through some of the front suspension. I wonder if you could make an up pipe that would curve around a stock k-member and then turn back in similar to that one?
Look at posts #42 and #63 here:
https://ls1tech.com/forums/forced-induction/985960-my-build-truck-c6-manifold-setup.html
Shows a C6 passenger side manifold with the up pipe inside a BMR "Turbo high clearance" K-member.
I will check back in on this tomorrow.
Old Oct 16, 2008 | 03:19 PM
  #85
awesome links!!
Old Oct 20, 2008 | 06:17 PM
  #86
1CAMWNDR's Avatar
Any decisions made yet?
Old Oct 20, 2008 | 06:39 PM
  #87
germeezy1's Avatar
Hello will this kit be F-body only?
Old Oct 21, 2008 | 09:51 AM
  #88
383lt1impala's Avatar
u need to make an impala ss kit.
Old Oct 21, 2008 | 09:55 AM
  #89
Silverado_13's Avatar
Self proclaimed VILLAGE IDIOT
Originally Posted by ModularTurbo
The following turbos will be available with the hotside base price: MP T-70, T64 & MP T76 / BW box unit T6 flange s475. Wastegate options will include JGS, tial, or turbosmart. I am going to try to offer the kit with customers choice of WG flange, will see.
What specific vehicle do those headers come off of Grr.
Don't know if this question was answered or not, but I believe those specific headers come from the Monte Carlo SS.
Old Oct 21, 2008 | 05:21 PM
  #90
it wan't answered yet. Thanks.
well as of right now I'm torn between the monte headers or the vette headers I won't know till the car gets back here and I take a closer look.
Old Oct 21, 2008 | 09:18 PM
  #91
NemeSS's Avatar
Well I do have a hotside that is available right now but its an A/C delete setup. It is pretty cheap though.
post price and configuration of said hotside.
or pm with info.
very interested.
Old Oct 22, 2008 | 01:38 AM
  #92
pm sent
Old Oct 22, 2008 | 12:42 PM
  #93
Grr's Avatar
Grr
A really good thing to look at is the monte header for the drivers side, this would eliminate having to relocate the alternator as well. I think you should just get one from the dealer and try it.
Old Oct 22, 2008 | 01:18 PM
  #94
Not a bad idea I will look into it.
Old Feb 28, 2009 | 11:17 AM
  #95
OK, after a somewhat long hiatus R&D has started back up. We are hoping to have some kits ready soon!
Old Feb 28, 2009 | 11:58 AM
  #96
Silver_TransAm's Avatar
Still planning on what we talked about. Pm me.
Old Feb 28, 2009 | 12:36 PM
  #97
boostedgtp's Avatar
interested
Old Feb 28, 2009 | 02:42 PM
  #98
Yes you have been slated for the first one Matt
Old Feb 28, 2009 | 03:22 PM
  #99
barnat's Avatar
Default Think ahead alittle
If your going to do this! think & plan ahead alittle like APS didnt do LOL If your kit is going around a stand up radiator,, make sure your leaving enough room in there for aftermarket rads also!!JMOand make sure your kit works with a good quality affordable Y pipe of your choice, unless your planning on making one for your kit which inturn will bring the cost up! Also , make sure it doesn't interfer with the sway bar LOL or anything on lowered cars !Good luck and dont skimp on the silicone hoses if any! At least 4 ply! You know how it works, Right.? LOL Either your going to be the most loved guy in the FI site or the most hated LOL
Good luck ,sounds like a plan man and if you do this and do it right this should really take off for you and one more thing and im sure all us us agree ,,, build this around a good quality turbo because your going to have to offer some type of warranty if saleing this kit with a turbo or you can build this kit around a good turbo and let the customer buy it themselves thus saving your self some MAJOR head achs and keeping your cost down BIG TIME!
Old Feb 28, 2009 | 04:01 PM
  #100
99bluefirebird's Avatar
How about coated stainless 1 7/8" primaries and a 5" downpipe option?
Oh wait probably not the market you are going for.
Here are some requests:
1) Coated hot side
2) Keep stock K member, if not at least UMI road race K
3) Keep A/C
4) Stock alternator location
5) Mounts for newly positioned radiator/fans
6) Position the air filter so that we don't have to worry about sucking up water if the turbo is mounted low.
7) The more welds and less clamps the better
8) Offer an 88mm turbo, 4" downpipe?
