turbocharging a 502. need some help
Old Oct 11, 2008 | 06:23 AM
marwan 502's Avatar
Default turbocharging a 502. need some help
i'v got a pair of holset hx40 are they good for a chevy 502. its a stock omc engine with 8.75: 1 cr. 10x for help
Old Oct 11, 2008 | 08:45 AM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
What level of power are you wanting?? HX40's in twin configuration can support anywhere from about 900-1100hp or so.
Old Oct 11, 2008 | 10:23 AM
marwan 502's Avatar
10x for reply. im planing to make 1000hp with twin configuration,but @ what boost & what about the lag, and @ what rpm they will spool, and what carb i must use. i have two hx50 also are they better. and do i have to modiffy the engine. 10x anyway
Old Oct 11, 2008 | 10:25 AM
Fast_94_Z's Avatar
consider running efi if your doing turbos. a coverted single plane with a throttle body and intake intake would do you real good.
Old Oct 11, 2008 | 10:28 PM
slow67's Avatar
Gingervitis Addict
Carbs can work perfectly fine on a turbo motor in blowthru or drawthru configuration (blowthru will make more power). You should visit theturboforums.com for blowthru stuff.
Old Oct 12, 2008 | 05:22 AM
marwan 502's Avatar
yes it will be a blowthu application
thanks for help i need more informat
more posts from all who knows about holset turbos and carburation
