View Poll Results: what are you running?
LS1 346
40.21%
LS2 364
1.03%
LQ9 370
17.53%
LS2 402
9.28%
LQ9 408
11.34%
LS3
0
0%
other
20.62%
Voters: 97. You may not vote on this poll
Old Oct 16, 2008 | 03:03 AM
SSilverSSurfer's Avatar
Originally Posted by tomz28
how much power you making bro
finishing it up right now, should be ready to tune soon, ill post the numbers when its done, im gonna bring the pain on the 4L60E
Old Oct 16, 2008 | 04:39 PM
sevanseriesta's Avatar
Engine: Forged 347 (built by me), Diamond -8cc pistons
Transmission: Art Carr 700R4, 3600 stall
FI: KYTP Cutom Twin Turbo, twin T76, 31X24X3.5 intercooler
Fuel: Dual in-tank Walbro pumps, Professional Products Fuel rails
Driveline: Stock 10bolt, 3.5" Drive shaft
Suspension: Spohn soild motor mounts, chasis mount torque arm, control arms, and panhard bar.
Goals 900rwhp at current build. and mid 9's at 150. Future goals are 1300 and 8's and be fully caged and NHRA legal for 8's by next year.
Things I would change as of right now nothing I do not have seat time yet but will starting tomorrow. I would however like to have my pipes coated.
Old Oct 17, 2008 | 02:38 AM
tomz28's Avatar
good info
some of you guys should have no issuses making 700rwhp with your setups
my car has made 694 on a dyna pak dyno
and 625 on a dyno dyamics but it traps 128 in a 3680lbs car which come out to be about 658 if you do the math
Old Oct 23, 2008 | 04:21 PM
MIGHTYMOUSE's Avatar
information i have been given says the ls2 is a stronger starting aluminum block
as far as cubes i keep them small for a few reasons
mileage
have a power adder so i let it make the power
want to leave as much of the structure in the block as possible. more metal = more stronger
Old Oct 23, 2008 | 06:14 PM
MY99TAWS6's Avatar
Under 1000 rwhp think ls2 is fine..over 1000 rwhp maybe lq9. way over 1500rwhp then lsx block. Just a rough guess though from things I have read. I figured I might someday be in the middle range but never would be over 1500rwhp and really can't see being anywhere near that in daily driving or even at the track the couple of times it going to be there. I bet most of us would be happy at 600 to 700rwhp especially on the street.
Old Oct 24, 2008 | 10:56 AM
Lawnboy's Avatar
Restricted User
How about the newer LS1/LS6 blocks?
I have a 2004 LS6 block, it uses the LS2 rear cover,
I heard something that the last of the 5.7 L aluminum blocks, were all LS6, like the one i have , and made just like the LS2 blocks for even more strength,
Does anyone know anything about this?
Old Oct 27, 2008 | 09:22 AM
mterveen's Avatar
stock 346 - currently building iron 408 for next winter install.
Old Oct 27, 2008 | 10:10 AM
tomz28's Avatar
370 is looking cheap too
Old Oct 27, 2008 | 10:34 AM
Photochop's Avatar
ls1 347
Old Oct 28, 2008 | 12:56 AM
tomz28's Avatar
how much power are you getting out of your 317
Old Jun 20, 2009 | 12:39 PM
MY99TAWS6's Avatar
Well you most all specs are in the sig
and forgot this was old poll but since been driving car more now update is in order.
408 ironblock. Heavier but strong. Original goal was 800rwhp auto ,850rwhp stick.
Now think 1000rwhp auto is reasonable and pretty sure fuel system and block can take that power level.
Not overly worried about weight, car is a fat pig so make up for it with power.
AFR 225s as wanted a thick deck head so not to worry much about blowing head gaskets. Still doubt will ever be past 15psi even if upgrade turbos over winter.Car is stupid fast at 8psi already and can always hit it with some spray my zex direct port kit is 75 to 300 shot.
Like my gt7 ling cam. very mellow no lope at all. Easy to tune. No cam surge. Went to 1.8s yella terras to get a bit more lift.
So really nothing that regret. Did originally want to go to a 427 but its not really needed, the 408 has plenty of grunt off boost and lots of torque on or off boost. It spools up the current smaller turbos very quickly. should still do a decent job on a bit bigger ones and again have spray if want instant spool up.Best of both worlds.
I guess if something ever happened to write off this motor might go to lsx block and maybe 6 bolt heads and then 427 or 454 size but really that is just stupid stupid torque and hp and could then go to like 1700 hp with bigger turbos and 300 shot but then need huge fuel system, maybe trans and rearend would start breaking etc. Would have zero traction at pretty much any speed etc.
Guys get way too carried away with trying to hit a certain power mostly for bragging rights. Admit mostly want 1000rwhp just for that.
600rwhp is nothing to sneeze at. Plenty on the street.And still fairly controllable.
At least with turbo build I can experiment and get used to different power levels.
Old Jun 21, 2009 | 01:27 PM
  #32
cablebandit's Avatar
lq9 408
etp 225 heads....got them for the thicker deck
patrickG specd cam...its tiny...230-234
I wanted a low revving motor with some torque to move my 4100# streetweight and 3.08 gears.
ls6 intake
I am very pleased with everything as far as the motor goes
In the future I'd like to go to a ls2 408 to drop some weight and run a little cooler as it seems the aluminum blocks do.
Old Jun 23, 2009 | 12:03 PM
  #33
cbr600rx7's Avatar
Stock bottom 346 LS1
228/232 114LSA
Duel Gold springs
Fast 60lb injectors
Stock LS1 heads, intake, and TB
TTI 60 trim street kit
Tuned with HP tuners by Ryan over at RPM in NC
451HP and 508TQ on a less then perfect day
