blower head experts within.
If I put a blower on a stock 346 and make 10 PSI and 500 RWHP, or I put a set of great flowing heads (which may have affected static compression) and cam on an even bigger motor, but only apply 3 or 4 PSI of boost... no matter what your theories are, the first circumstance can take 320 RWHP to 520 while the 2nd can take 420 RWHP to 500.
It happens.
What I am saying is, there is something else that is causeing your horsepower drop. But that's just my opinion. I'd do a compression test/leakdown to see if everything is OK in there.
-Geoff
He may have some problem other than the heads... who knows? But, my conjecture still stands (for me
)... if a set of heads make you lose enough boost, the heads may not make up the power. Key word is "may".
With a fixed pulley setup you are flowing the *same* CFM. If the compressor doesn't have to compress it as much that should *increase* your effeciency, not decrease it.
It's not a question of "loosing" boost - all the air is still there, you are just flowing it through in a less restricted fashion.
All I am saying is that there is something wrong other than 2 psi of boost missing. I understand that airflow means everything, I am not trying to start an argument on that. But, you can use my numbers to ballpark horsepower from boost. So if you are missing 2 psi and 80 hp, there is probably something else going on. That's all I am saying here.
-Geoff
why were the heads pulled? was the motor hurt before? same dyno? same conditions? same valvesprings as mentioned?
lastly your timing and fueling set up *should* have remained virtually unchanged..same air in the cylinders so same fuel and spark needed.. you say the timing is back up to where it was.. where is the a/f vs. where it was before (put it all back
) the heads where changed because the "old" heads only had exhaust port porting and slight intake port touch up. the new heads have the same exhaust job but have an extensive intake port job too.
the valve springs where changed from 918's to 978 or 987 ( which ever one had the higher pressure #'s)
timing remained the same , the air/fule had to be tweaked cause the injectors on the car now are bigger (old ones where maxed out), the A/F is set btw. 11.5 and 12:1 now.
i just find it strange that a motor like that would get such low numbers, i know that stock ls1's are in the 200~220 range, but a 6.0 with around 9.8 compression short block ( with ls1 heads) should be in the 170~180 range, right?
-Geoff
I was told that full point of compression is worth 3% more power. Even if you went down two full points that's not going to explain the loss right?
Are you sure the belt is not slipping?
ARe you sure your blower is not messed up?
how can i tell if the blower is messed up? it spins normally when out of the car and all the blades seem fine.
the compression on that motor is supposed to be 9.8:1 with ls1 heads, so i'm guessing with 6.0 heads it's more like 9.4 maybe ( not sure so if some one knows how much compression 6.0 heads drop please tell me)
you guys have my confused now, 150 psi = 8:1 and 105 psi = 9:1??????
prostockjohn, by "point" do you mean a change from 10:1 to 9:1 or a change from 9:1 to 9.1:1?? ( i'm guessing you mean 10:1 to 9:1)
6.0 heads (I have a set of them) are around 70cc's so they are a modest drop in compression over stock 67cc LS1 heads. Maybe you went from 10:1 to 9.5:1.
-Geoff
A belt is a cheap/quick enough thing to do just to check.
Not to be a dick but FI is tedious and these are the things you have to go through when you really start doing a powerful FI motor. I've been through it, friend have been through it and it sucks. But its ALL worth the trouble when its running right, just dont give up
Start making a checklist of things that "could" be wrong and go through them one by one and tell us as well.
Hopefully we can help you find your horsepower again.
Wow. Off a 500 HP motor, that's only dropping to 485 HP. If an NA motor were 10:1 and you dropped all the way back to 8:1 it would only lose 30 HP.
Why would people quibble over whether they should cut back to 9.5:1, 9.0:1 8.5:1, etc., if you lose only 6% power by dropping all the way back to 8.0:1 Static CR? It's seems it would be no question, with the ability to run less octane and crank the boost so much higher.
could the valve springs be too stiff for the lifters?
could the lifters be collapsing under pressure? the car does have 1.8 rockers and the cam's lift is .600
the valve springs are 987's or 978's , i'm not sure but i'll ask.
