3 bar map??
Old Oct 20, 2008 | 11:29 PM
Rickys S/C Z28's Avatar
Default 3 bar map??
were can i get one what all goes into hooking one up and does anyone have a part number?
thanks Ricky
also were can i get a 02 senor for my aem wideban that does not cost a lot?
Old Oct 20, 2008 | 11:45 PM
navymitch12's Avatar
Ricky...this is an easy one
http://www.fuelairspark.com/Products...individual.asp
For hooking it up you gotta run a hose from your intake to the MAP because most of them do not just hook into the back of the intake. Then hook up the wires..Speed Inc sells a harness and they also carry the FAST sensor.
As far as the sensor for the wideband i would check with AEM directly. Didnt you just get that wideband? Sensor already going out?
Old Oct 20, 2008 | 11:47 PM
Also Gm Part Number
3 Bar Sensor GM#12223861
Old Oct 20, 2008 | 11:48 PM
thanks mitch and yep i just got it about 6 month ago i ran race gas i time and i guess it killed it??
Old Oct 20, 2008 | 11:49 PM
Originally Posted by navymitch12
Also Gm Part Number
that is what i was looking for!!!!
thank man
Old Oct 21, 2008 | 12:19 AM
leaded race gas? they should all be fine if you used unleaded race gas...weird i guess
so plan on running over 15psi? sounds exciting
Old Oct 21, 2008 | 12:52 AM
Frost's Avatar
Here is a link to the GM sensor(s) and adapter harnesses that allow them to be plugged into the factory harness: http://www.lsxtune.com/shop/index.php/cPath/129_143
Old Oct 21, 2008 | 11:11 AM
dschmittie1's Avatar
AEM uses a GM wide band 02 sensor for there gauge. I just got a new one to replace mine that went bad. GM part number is 12575657 I picked one up from our AC delco distribtor for $77 You may have to pay a little more since I got mine at cost.
Old Oct 21, 2008 | 03:54 PM
great guys thanks and mitch yes i plan on running as much as 17-20 psi!
Old Oct 21, 2008 | 05:29 PM
cablebandit's Avatar
i got a 3 bar WITH the plug/play harness for 65+7 shipping
Old Oct 21, 2008 | 05:48 PM
Frost's Avatar
I sell that sensor for $65 here: http://www.lsxtune.com/shop/product_...roducts_id/534
It's interesting to note that Bigstuff3 uses the same sensor...
Old Oct 21, 2008 | 07:45 PM
i think thats the same one that the wideband commander by dynojet uses as well...good price Frost
Old Oct 21, 2008 | 11:27 PM
forst you will be getting a call very soon thanks man
