P1SC with Custom Bracket
You're going to peg the maf but most tuners know how to work around this, without having to go speed density. We have kept the maf on a lot of horsepower builds up through 700 rwhp without any problems. Bob
Hopefully the tune will get all squared away before too long. Just have to be able to find the time both the tuner and I are free to get together.
Are you asking how it is put onto the car compared to the SDCE or how does it perform compared to the SDCE?
There were some design aspects of the SDCE that I personally thought could have been done better.
- Spacing the pulley so far off the tensioner arm places undue stress on the system. Twisting loads tensioners were not designed to take. Mine keeps the pulley right next to the arm as the manufacturer spec sheets recommend.
- I did not have an ATI bracket to have modified so that would have been added expense.
- Special tools needed to operate the tensioner. I can use a standard 15mm open wrench to operate my tensioner.
- ATI & SDCE both not using the second 3/8" mounting hole on the super charger. My bracket is wider and using the 6th bolt hole completely ties in the top half of the bracket with the J section.
