YS Trim beast is running
The boost will be whatever we get with our pulley configuaration, 8" crank pulley, 2.85 blower pulley, and good belt tension.
Scott, I'm willing to buzz the motor to 7200.
I should be picking it up tonite and might drive it.
That hog might run like it is supposed to
BTW, I think it should run in the mid 140's...at least. Renegade cars with same blower are in the 150's. That hog might run like it is supposed to
BTW, I think it should run in the mid 140's...at least. Renegade cars with same blower are in the 150's. http://www.warperformance.com/greg.htm
Congrats on getting the car finished PSJ and I better see you running as fast as this Mustang cause you got a Chebby V8
I can get plates for it.
Renegade NMRA guys run 8 rib belts, and no cogs.
I thought Chris Sikora (Z9's) was using a Cog setup with his YS-trim blower as well??
Chris has a cog setup on his car.
It would not bother me to change the 8 rib belt once a month if I am racing a lot.
