Quick Compression check calculation
Old Nov 5, 2008 | 12:57 PM
tim99ws6's Avatar
Default Quick Compression check calculation
hey guys,
I am sure someone here can run the # real quick:
Ls1 motor
.010 overbore
Flat top pistons w/ 4cc valve reliefs.
6.0 heads
Stock rods/Crank
Stock MLS gaskets
What compression would that sit at?
Old Nov 5, 2008 | 01:04 PM
Yellowsierra's Avatar
Originally Posted by tim99ws6
hey guys,
Ls1 motor
.010 overbore
6.0 heads
Stock rods/Crank
Stock MLS gaskets
About 9.3-1 depending on a few things.
Old Nov 5, 2008 | 01:09 PM
tim99ws6's Avatar
What are the few things? I would be happy to give as much info as possible. Am i crazy to try and run my flat top pistons with valve reliefs for turbo application? the piston itself is forged, but has anyone else had any success with this?
Old Nov 5, 2008 | 01:15 PM
Yeah those pistons should work great... A few things would be Cylinder CC size. IF unmilled the 6.0 heads are around 71-72cc. Another factor would be how much the pistons pop out of the block. Im guessin you would be using 6.0 or 6.2L MLS head gaskets since your running 6.0L heads. 9.3-1 sounds like a great number for a Street FI car. Heres a good Compression Calculator that I use. http://www.rbracing-rsr.com/compstaticcalc.html
