ProCharger rebuild begins!
Old Nov 13, 2008 | 07:19 AM
Superado's Avatar
11 Second Truck Club
hey Bob-
w/ the D1, I now basically have the same set-up as Mike had...
what injectors did you run on that set-up?
I didn't see it mentioned in the write-up on your website...
thanks!
Old Nov 13, 2008 | 07:47 AM
EPP's Avatar
EPP
Originally Posted by Superado
hey Bob-
thanks!
I believe we used the Siemens 60lb injectors. We generally get by with them through 750 rwhp, past that we go with the Delphi 96lb injectors and use the AEM controller. Bob
Old Nov 13, 2008 | 08:02 AM
cablebandit's Avatar
thanx Bob. we are thinking the 60s will be enuff for Als setup. Now we need more fuel pump....dont think the single walbro will make it with the msd voltage booster but it might be close since he is running meth as well
Old Nov 13, 2008 | 08:27 AM
Rickys S/C Z28's Avatar
Originally Posted by 9t8z28
I don't really start making power until around 3K. So possible the D1 could help?
i start makeing boost at about 3k also but the thing is im at 13psi at like 5500 and still going up you know
Old Nov 20, 2008 | 10:12 PM
Superado's Avatar
what a VICIOUS circle!
new D1
need larger injectors
new injectors
need additional fuel pump!
thanks to APF for hooking me up!
MSS will be spinning wrenches tomorrow evening!
Bosch 044 in-line being added to the mix...
track on Saturday!
Old Nov 21, 2008 | 04:25 AM
EPP's Avatar
EPP
new D1
new injectors
track on Saturday!
The Bosch 044 will do the job, good choice! Must be nice being able to go to a track at this time of the year! lol We had snow last night! Bob
