HELP with setup
Old Nov 6, 2008 | 04:49 PM
dasorcha21's Avatar
Default BIG HP SINGLE TURBO CORVETTE questions
So im confused with turbo sizing let me explain my setup and goals and limitations...
the car is a 98 corvette a4
the motor will be a 366ci
heads that flow over 370cfm
built a4
2.73 gears
3500-4000 multi disk stall
the hot side is from hinson motorsport's single turbo kit.
which limits me to t4 flange turbo and 3inch downpipe.
and also limits the size of the turbo to the physical dimensions of a T76 or T78
my goal is for the car to have 800hp daily driven and 1000hp on race gas.
now the issue is what turbo would get me there with the above description and limitations?
thanx for the help in advance
Old Nov 6, 2008 | 05:39 PM
67Firebird455's Avatar
You're almost going to need a T6 flange turbo to get those numbers with 336 cubic inches of fury. Generally, running a T4 and trying to get those numbers will place you way off the compressor map. I had heard about some sort of "compact" setup, but I'm not sure if it will get you 1000rwhp, even on race gas.
Old Nov 6, 2008 | 05:43 PM
dasorcha21's Avatar
im sorry just edited it
i meant 366ci
Old Nov 6, 2008 | 05:46 PM
That's better... explain a little more on that turbo you've got there...
Old Nov 6, 2008 | 05:49 PM
dasorcha21's Avatar
i dont have one i need help picking one out that will meet my hp goal and 3inch downpipe and t4 flange limitation
Old Nov 6, 2008 | 05:56 PM
Forcedinduction's FI66 with an 88mm wheel MIGHT get you close. A precision PT88 also flows something like 125lb/min, which is good for around 1000rwhp.
Old Nov 6, 2008 | 05:58 PM
Borg warner (Airwerks) also makes a good unit for that kind of power...
The ST80, but I think with a T4, you're going to still have some issues with back pressure vs a T6 flange.
Old Nov 6, 2008 | 09:33 PM
dasorcha21's Avatar
anybody else?
Old Nov 7, 2008 | 04:20 PM
dasorcha21's Avatar
nobody has input?????
Old Nov 7, 2008 | 04:36 PM
GT67METHV's Avatar
67firebird455 won't stear you wrong...
other folks may confuse you.
Old Nov 7, 2008 | 04:37 PM
dasorcha21's Avatar
i checked with half of those turbos. some are to big dimensional wise? and others cant use a 3inch DP
Old Nov 7, 2008 | 05:12 PM
GT67METHV's Avatar
let the fabricating begin. lol
you had to have 1000 hp didnt you?!
Old Nov 7, 2008 | 06:24 PM
Appreciate that man...
A lot of the bigger turbos will use a larger DP than 3", it HAS to be 3"?
Old Nov 7, 2008 | 06:52 PM
dasorcha21's Avatar
i do appreciate your help and knowledge. from my understanding the kit comes with a 3in. dp. here are some pics
Old Nov 7, 2008 | 06:56 PM
Eeesh, that's rough. That is one tight squeeze in there. I personally wouldn't do it, but you could always reduce from a 4" DP to 3" since you're not going to be running it at max all the time, but I honestly believe you'll lose some efficiency with it being choked.
Old Nov 7, 2008 | 07:01 PM
dasorcha21's Avatar
hence the question of with what limitations i have to work with (t4 flange, 3inch downpipe, hood clearance) would i even be close to touching 800hp?
im not to good at looking at compressor maps and figuring out if a turbo is gonna choke etc... thats why i would like people who have experience or are experts at this to give me a little bit of help.
Old Nov 7, 2008 | 07:04 PM
dasorcha21's Avatar
would a T78 or even a 78GTS work?
Old Nov 7, 2008 | 09:36 PM
A 78GTS is gonna get you very close. It'll be blowing its lungs out, but you may be able to get there with that turbo.
Old Nov 7, 2008 | 09:42 PM
dasorcha21's Avatar
what are your thoughts on the overall hot side plumbing?
Old Nov 8, 2008 | 12:26 AM
I think what you have now will take you a ways. Looks good, no pinches, mandrel bent, and 3". I'd try and find a 76GTS and see how it works out, what kind of boost do you WANT to run, and what kind of rpm does the motor see?
