sts turbo set up
Old Nov 8, 2008 | 10:13 PM
GM WORLD CLASS's Avatar
Default sts turbo set up
my buddy just got his sts set up. he knows nothing about cars but he has a variable boost set up and on high boost he wants to run 18lbs. i advised him that its extreme for a v8, but he wants a second opinion. any suggestions for a good hi boost?
Old Nov 8, 2008 | 10:33 PM
shawn_c992001's Avatar
8 psi.
Old Nov 8, 2008 | 10:35 PM
about anything higher and you need new springs due to valve float. after that forged bottom and lower compression.
And upgrade the damn fuel sytem!
Old Nov 8, 2008 | 11:19 PM
trans2000am's Avatar
does he have a built trans?rear end?motor? fuel system? if not on 18pounds=kaboom on everything
Old Nov 9, 2008 | 06:09 AM
koolaid_kid's Avatar
More info needed. What is his setup? Completely stock LS1? Intercooler?
Lots of money to replace grenaded engine?
I run 4 and 8, but I also have methanol injection.
Old Nov 9, 2008 | 08:39 AM
Sluggish's Avatar
Also what size turbo, if its something small like the 60mm it won't put out enough to get to 18psi.
Old Nov 9, 2008 | 09:33 AM
trnsfmr99's Avatar
If he did have double-lift springs for the turbo cam, how much more could he go up with the boost if the rest of his setup was stock?
Old Nov 9, 2008 | 09:42 AM
lifeisgood's Avatar
theres a reason why sts says to have the boost level at 8 psi. unless he has meth dont push it. unless forged internals and fuel upgraded.
but even with that he needs a good tune to be safe
Old Nov 9, 2008 | 09:57 AM
MY99TAWS6's Avatar
Personally nice safe 5psi on stock motor. Add at least 42 pound injectors and good fuel pump like racetronix in the tank and of course tuning then could go up a bit to maybe 7 or 8 max and would do better valve springs. Much past 8psi likely be saying bye bye to engine.
Old Nov 9, 2008 | 02:20 PM
EPP's Avatar
EPP
Have him read everything we did to this Camaro. Bob
http://www.exoticperformanceplus.com...Car.php?car=32
